Question about Dishwashers
Dishwasher doesn't have any water
I disasembled the water inlet valve all the way down to the solenoid plunger that electrically lets the water in. The filter screen was very dirty and cleaned.
The plunger doesn't have any breaks and has suction.
    President:
  • 2,651 Answers
Well of yo have cleaned the screen, andyorgting powerto the valve andstill no water to the unit, soundsas if the valve needs to be replaced
Posted on Jan 26, 2009
Maytag performa dishwasher, model # PDBL390AWB.
Sounds like to me you have a water restriction somewhere. Double check and make sure that the main water valve coming into your home is fully open. Make sure the water shut off valve(s) going to the dishwasher both have adequate water flow and that means testing them before being connected to dish washer. If that checks out okay, possibly the plunger that opens and closes in the electric water solenoid is sticking and not opening up al the way since the unit has been in storage for all that time. Sometimes tapping on it when it is in operation can free up that sticking plunger and you may get full water flow restored again. If not, solenoid may have to be replaced. Hope this helps out.
Mar 09, 2014 | Dishwashers
Dishwasher not filling
The water float switch, located on the inside bottom of the machine, may be stuck in the up(off) position keeping the water valve from functioning. This is a safety device that turns the water valve off when the machine fills in order to keep it from overflowing.
The water inlet solenoid mounted on the inlet valve under the bottom front may also be malfunctioning not allowing the water valve to open and fill the machine. If electricity is present at the solenoid terminals when the machine is in fill cycle, then check the solenoid coil to see if it is open(no continuity). Also, the timer may not be calling for water/ sending voltage to the inlet valve solenoid.
I would start by manually operating the water float valve a few time to see if that helps. You should hear a microswitch click each time the valve stem is moved up or down by the float. If not, check to see if voltage is getting to the float switch and the water inlet valve solenoid.
Most(if not all) machines have a safety cutoff switch which activates when the door is opened. That switch could also be malfunctioning not allowing voltage to the water inlet valve solenoid in fill cycle.
Jan 26, 2012 | Meiko Dishwashers
I close turn on and no water
if you can hear pump kick in then stop..... then you need to change valve inlet...
Feb 26, 2011 | Haier HDB24EA Built-in Dishwasher
Water is on and reaches the hose but does not go into the dishwasher.
Check the beginning of the hose for debris. If not that, take the front bottom panel off and remove the IN hose from the pump. There is either a stuck plunger or a clogged screen.
May 13, 2010 | Bosch Dishwashers
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
Tablet not dissolving, dishes not clean
Hi Trina. I wish I was nearby as I would come over and take care of this problem for you.
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
May 08, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Bosch Diswasher SGS4012GB/13
First check the machine is getting electricity (and the problem isn't a blown fuse!)
A very likely cause is that the solenoid on the inlet valve has gone. Rarer possibilities to consider are water turned off at the mains, a blocked inlet strainer (where the inlet hose mates with the valve), or a problem with the programme controller.
The inlet valve is near the top of the machine, and is the thing the hose from your outside water supply screws into. The solenoid is the electrical bit that clips onto the top of the valve body.
I suggest you go out to your local appliance spares shop and buy a replacement solenoid for not much, fit it and see what happens. It is possible to do a series of tests to confirm first that really is the problem - but with the solenoids being cheap, I'm inclined to suggest not messing around with test gear, water and mains electricity.
When replacing the solenoid, make really sure the machine is unplugged from the electricity supply.
Usually best to take the top panel off to gain access (try taking the trim across the back of the top panel off, then sliding the panel off backwards).
Disconnect the cables from the old solenoid. Prise it off the valve body. Snap the new one on in its place and refit the cables (it doesn't really matter which way round they go, but one way will probable look neater than the other).
A.
Jul 15, 2008 | Bosch SHU9915UC Dishwasher
Kitchenaid dishwasher service manual
Water leaking from tub above motor. Is there a schematic online to show how to replace seal?
Mar 08, 2008 | Dishwashers
Dishwashers Logo
85 people viewed this question
Top Dishwashers Experts
