Question about GE WBSR3140DW Top Load Washer
GE WASHER, MODEL WWSE5200B1WW, WONT FILL OR START UP
  • 2 more comments
  • Donna Hall Jan 19, 2013
    nope, unplugged it and plugged it back in outlet. It won't turn on at any level.
  • Richard Roth
    Richard Roth Jan 19, 2013
    Look on the lid and see if the magnet is still attached to it. The magnet is for the lid switch which will control all the washer functions.
    yes it is still attached. I tried to unscrew it but it requires a star studded type not a regular phillip head and I need that type to undo the piece. I'm looking at a diagram of parts for my washer now. The push/start button could be out too. Both of these parts are relatively cheap too.
    I will try replacing both parts; magnet & start button first to see if it corrects the problem. My washer is at least 10 yrs old so I may be in for a new one anyway.
    Top Expert:
  • GE Master
  • 9,472 Answers
If you set it to the spin cycle, will it spin?
Posted on Jan 19, 2013
    yes but it won't do anything but light up the panel. No action at any level
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: GE Washer-Doesn't Fill When it Supposed to.
It is most likely a pressure switch. This is the water level switch. As water fills the tub, air pressure builds up in the rubber hose going to the switch. When the pressure is high enough for the water level setting, it trips the switch and puts the unit in wash cycle. Remove the control and start the machine. While it is agitating, remove the hose from the switch and see if the washer starts filling. If so, blow through the hose and see if something has clogged it. If you have a volt/ohm meter you can check across the terminals while you blow into the switch to see if it is working. Let me know what you find out.
Posted on Oct 19, 2007
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Washer agitates when I try to fill it up with water,wont fill
You have a bad water level switch or a clogged plastic hose that goes to the water level switch.
Use a putty knife to open the front panel. The clips are at the top right and left sides just below the top lid. Push in on the clips and pull out on the panel.
On the left side of the tub you will see the air dome with aplastic hose connected.
Remove the hose and insert a small wire into the air dome hole to clean it out ouf soap scum. Then, blow through the hose and listen for a faint click in the water level switch. Also check the hose for a hole or being pinched.
The set the timer for spin and run a spin cycle then retry the water level and wash cycle.
Posted on Apr 01, 2009
SOURCE: My GE washer won't fill with water; will agitate
The hitachi machine bring an error message C1B1. Please assist
Posted on Aug 01, 2009
Ge GTWN2800D1WW washer wont fill on start but will do drain and spin cycle....help
What do you mean? It not fill up or no water is coming in?
Did you hear some humming noise?
Check the input water tap... close be closed or blocked...
Dec 01, 2015 | GE Washing Machines
My ge top load washer wont start already change out board. not sure if my lid switch or magnet is bad?
Sure does sound like your safety switch isnt working. To be sure please give me model number to unit and I can do some checking and get right back to you
Apr 11, 2015 | GE Washing Machines
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Jun 01, 2010 | Washing Machines
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE WBSR3140DW Top Load Washer Logo
360 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
