Question about Sony Vpl-x2000 Video Projector - Works Great
Emergency mode If he get power for a second all keys get light and the display shows system checking.... after one more second everything is off and the display shows need upload in emergency mode how can i start the projector? I only have the projector, no remote,... The user manual and owners manual from sony say nothing about the mergency mode
3 Suggested Answers
  • 11800 Answers
SOURCE: Sony projector VPL-HS50. Makes clicking noise
The clicking noise is generated by the power relay. This is what happens: the power source starts - the power relay is engaged; a faulty part inside the projector (most likely the ballast board - the one that power the bulb) starts to draw way more power than it should; this is detected by the protection system of the source that shuts it down in emergency mode - the relay is disengaged; without power the protection system is reseted, this allows the power source to restart; this cycle takes place a few times , until the current drawn by the ballast drops to a tolerable value and the protection system can shut the power source in a controlled manner.
The only way to fix it is to open the projector and test it to identify and replace the failed component/board. This is a job for a person experienced in repairing electronics.
Posted on May 09, 2011
SOURCE: My Sony Data Projector VPL CS6 is stuck in
I tried the emergency mode and recovered the powered mode. just make sure you can turn the adjuster ( that big grey plastic screw) freely and leave it that way (don't tighten it or put the **** back in). try turning it on. works for me..
Posted on Jun 21, 2011
How to reset a samsung galaxy prime that is locked to gmail account with forgotten password
This will return the phone to factory settings with NO account.
This will also delete EVERYTHING on the phone.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Home key, then press and hold the Power key.
  3. When the Samsung logo screen displays, release only the Power key
  4. When the Android logo displays, release the Volume Up and the Home key ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
  5. Press the Volume down key several times key to highlight 'wipe data / factory reset.'
  6. Press Power key to select.
  7. Press the Volume down key until 'Yes -- delete all user data' is highlighted.
  8. Press Power hey to select and start the master reset.
  9. When the master reset is complete, 'Reboot system now' is highlighted.
  10. Press the Power key to restart the device.
Oct 31, 2016 | Samsung Cell Phones
My volume button doesnt work an shows no display when i turn it up and down? Everything else works.
If you have a device like the Nexus 6P or Nexus 9 running stock Android, then these are the steps required to boot into Recovery mode:
  1. Hold down the Power key and select Power off. If the touchscreen is unresponsive, then you can simply keep holding down the Power key for several seconds until the device turns off.
  2. Press and hold the Power key and the Volume down key. You should see the Android mascot on his back, a bunch of information about your device, and Start at the top of the screen.
  3. To navigate through the menu options, you use the Volume up and Volume down keys. The Power key is used to make a selection. Press Volume down twice, and you should see Recovery mode in red up at the top right. Press the Power key to select it.
  4. The white Google logo will pop up followed by the Android mascot on his back again with the words No command underneath.
  5. Press and hold the Power key and the Volume up key for around three seconds, and then let go of the Volume up key, but keep pressing Power.
  6. You should see the Android system recovery options pop up at the top of the screen. Use the Volume keys to highlight the options and the Power key to select the one you want.
Sep 16, 2016 | Audio Players & Recorders
How do I turn off the silent mode so the phone will ring?
For the Uniden model D1680 & similar...
You ENTER "Silent Mode" by pressing and
holding the [ # ] key on the handset for a few
seconds until the display reads "Please Wait".
It will (chirp) and display "Silent Mode ON".
You can EXIT "Silent Mode" by pressing and
It will (chirp) and display "Handset #".
Another easy way to end "Silent Mode" is to go
to the BASE and press the [ANS ON/OFF]
button to turn off the answering machine system.
(Push the [ans] button, do not unplug the power)
"Silent Mode" will clear a moment later while the
control voice tells you "Answering System is OFF"
Now you can again turn on the answering machine
system as desired.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
Why is my laptop screen black during startup?
I recommend you to connect an external monitor and check if there is display on it. Press 'Windows' + 'P' on the key board to get display on the external monitor.
I also suggest you to run diagnostics on display. To test the display shut the system down, next press and hold the letter 'D' on the keyboard and press the power button. This will initiate diagnostics on the display. Please check if the colors are displayed across the screen without a problem.
You may also try this step that is shut the system down, remove the battery and disconnect the ac adapter, press and hold the power button for 20 to 30 seconds. Now connect only the ac adapter and wait for 30 seconds , press and hold the Fn key on the keyboard and power on the system. This will run diagnostics on the hardware components and also the display.
check also:
Please let me know if there is any light on the keys shows below:
5557.led-status.png-
if any of these are flashing in a sequence
please reply back with results
Jun 08, 2014 | Dell Latitude E5500 Laptop
My maytag neptune front load dryer model #MDE9700AYW shows a T5 code and will not heat.
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Nov 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
I have the code but only says on screen that it is waiting? on my kenwood kdc 6090r
• Security-related information
1. Forced Power ON mode (All models)
Even when the security (Mask key) is approved, resetting
the unit while holding the ATT and Preset 4 keys makes it
possible to turn the power ON for 30 minutes. After 30
minutes have elapsed, it is not possible to return to the
previous condition unless the unit is reset again.
2. Method of registration of the security code after EEPROM
(Tuner Unit ***'y) replacement
(Code security model)
(1) Enter the test mode. (See " 1. How to enter the test
mode")
(2) Press the CLK key to enter the security registration
mode.
(3) Enter the code using the Preset 1/2/3/4 keys.
Example: To enter "3510"
• Press the Preset 1 key 4 times.
• Press the Preset 2 key 6 times.
• Press the Preset 3 key twice.
• Press the Preset 4 key once.
(4) Press and hold the DISP key for 3 seconds until
"APPROVED" is displayed.
(5) Exit from the test mode. (See " 2. How to exit from the
test mode")
(Note) All Clear is not applicable to the security code of
this model.
3. Simplified method of clearing the security code (K Type
only)
(1) While the code entry is requested, press and hold the
VOL UP key for 3 seconds while holding the DISP
key pressed. (This should turn "----" off.)
(2) Enter "KCAR" from the remote. (Same way as the 00
model)
Press the 5 key on the remote twice, then press the
Track Up key. (This enters "K".)
Press the 2 key on the remote 3 times, then press the
Track Up key. (This enters "C".)
Press the 2 key on the remote once, then press the
Track Up key. (This enters "A".)
Press the 7 key on the remote twice, then press the
Track Up key. (This enters "R".)
(3) The security code is cleared and the unit enters the
ALL OFF mode.
(4) If you commit a mistake in the code entry, the unit
enters the code request mode again.
4. Method of writing the Mask key while the EEPROM is in
the initial status
mode")
(2) Press the CLK key to enter the Mask key registration
mode. "TRANSMIT1" should be displayed now. The
display at this time should show " < > " in place of " [ ]
(3) Point the Mask key remote toward the light sensor,
and press and hold its key for more than 0.5 second.
(4) When "TRANSMIT2" is displayed, press and hold the
key on the Mask key remote for more than 0.5 second
again. The first and second counter codes are not
compared at this time.
(5) When "APPROVED" is displayed, the write operation
is complete. Now the demonstration mode is initiated
and the test mode is terminated.
(Note) In the same way as previous models, if 30 minutes
have elapsed with no code written, an error occurs
and the power is turned OFF.
5. Method of initializing the Mask key
(How to reset the unit from the Mask key approved condition
to the factory condition)
mode")
(2) "TRANSMIT1" is displayed and the Mask key entry
request mode is initiated.
The display at this time should show " ∗ ∗ " in place of
(3) Press and hold the key on the Master key remote for
more than 3 seconds.
key on the Master key remote for more than 3 seconds
again.
(5) When "APPROVED" is displayed, the Mask key is
cleared, the demonstration mode is initiated, the test
mode is terminated and the unit returns to the factory
condition.
6. Method of clearing all Mask key-related data
mode")
(3) Point the Master key remote toward the light sensor,
and press and hold its key for more than 3 seconds
(until the level display shows the full condition).
(4) When "TRANSMIT2" is displayed, hold the key on the
Mask key remote for more than 3 seconds again.
If "TRANSMIT1" is displayed in place of "TRANSMIT2",
restart the procedure from step (3).
(5) When "APPROVED" is displayed, all security data is
cleared and the unit returns to the condition before
Mask key writing with the EEPROM in the initial status
Apr 05, 2010 | Kenwood KDC-6090R
I have a 2008 corolla. It has an auto light when the car needs an oil change. I need to know how to reset it.
Look in your owners manual and go to the part that explains the different symbols on your dash. Look for that service reminder and it should tell you what page to go to to learn more about that. Somewhere there should be some wording to the effect that "When you have your car serviced by a certified Toyota dealer they will reset it for you. In the event that someone other does your maintenance then this is the procedure to reset......."
Oct 04, 2009 | 1998 Toyota Corolla
Printer displaying paper out on on control panel
You may be able to calibrate the paper out sensor to fix the problem.
Set the printer to Offline.
Press the Enter and Line Feed keys together and hold pressed until the alarm sounds (typically 3 or 4 seconds).
You should have seen briefly displayed, Tech Access On
The display will again say Offline.
Press the Mode Key, display will show Offline Normal.
Press either Arrow key until display shows Offline Test.
Press the Forms/1 key.
Press either Arrow key until display shows Test Diag.
Press the CPI/2 key.
Press either Arrow key until display shows Diag Prnt Cal.
Press the LPI/3 key.
Press either Arrow key until display shows Pap Out.
Press Enter
Follow the instructions on the LCD display, which will advise on removing and reinserting the paper.
After you have compleated the calibration place the pritner ONLINE to exit the menu.
And finally turn the printer power off, wait ten seconds and turn the printer power on again.
If the problem still exits you may need to repalce the lower tractors or the main logic board.
Sep 11, 2009 | Tally Line Matrix T6100 Printer
Theft system 2000 malibu ls
try this: turn key on, crank starter for 1 second, leave key on for 10 minutes. after 10 min. shut key off and repeat 3 times. (on second try, crank a sec. or so longer, the reprogram may take off right away. if not, repeat make sure battery is strong, key could be on for 1/2 hr. sometimes engaging emergency brake before key is turned on prevent daytime running lites to come on to save battery power (if equipped). been through it, thought i'd mention it
Nov 16, 2008 | 2000 Chevrolet Malibu
Sony Vpl-x2000 Video Projector - Works Great Logo
23 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
