Question about Motorola Radio Communications
2-way radio causing voltage to spike
We had to install a new voltage regulator in the alternator in one of our fire trucks. We can now not key the Motorola 2-way radio in our truck without the voltage spiking. Do you know what could be causing this and is there a way to block the radio transmissions from affecting the alternator?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem indicates that the RF from the Motorola is being received by the electronic regulator of the alternator and is erroneously factored in as sensor/triggers. Simply stated, the RF causes the regulator transistor to conduct more allowing higher voltage output. There could possibly be two ways of addressing the issue: regulator/alternator side and/or the Motorola side. Things that you could try:
  • shunt a reverse protection diode across the output of the alternator to the ground;
  • install filter condensers on all the wires leading to and from the alternator;
  • wire a ground strap (not a ground wire) from the firetruck's - terminal of the battery to the alternator housing;
  • check/improve (lower down) the SWR of the antenna;
  • if you are using a magnetically mounted antenna, replace with a gutter mount or similar mounting brackets;
  • wire a ground strap (not a ground wire) from the antenna mount to the radio to the body of the firetruck to the alternator to the - terminal of the battery.
A ground strap is a flattened braided electrical wire unlike the common stranded auto electrical wire.
Pls post back results. Good luck and thank you for using FixYa.
Posted on Jan 26, 2009
2002 Crown Vic overcharging.
unless the voltage regulator is in the alternator, changing the alternator was a waste of money
the problem is in the voltage regulator which in your case a separate unit or in the ECM
voltage is regulated to 14.5-14.8 volts dc and any excessive voltage can burn the ECM and cause all sorts of electronic failures
time to get an accredited auto electrician involved as you are wasting money doing it yourself
Nov 09, 2017 | Cars & Trucks
I have a 04 explorer keeps blowing ignition fuse. Need to no why. It just started today. Please help
Have your alternator checked. The voltage regulator may be failing causing spikes in the voltage, which will blow fuses (and possibly damage other things). Another thing to check is the ignition coil for shorts.
Jan 12, 2016 | Cars & Trucks
2005 gmc sierra head lights brighten and dim while driving
This is caused by either a poor ground connection to the head lights or an overcharging condition taking place in the voltage regulator of the alternator, the spikes in output voltage causes the head lights to brighten up.
Aug 31, 2011 | 2005 GMC Sierra 1500 Hybrid
2000 Mitsubishi Galant ES 2.4 liter, the electrical issue is that the battery seems to lose power and trips out the radio and will not start and have to put in radio code all the time and fuses seem to...
How old is the battery? More than 3 years it may be failing. Summer heat will test the battery limits.
Could be the alternator / regulator is bad causing large spikes in the voltage.
Take to an Auto Zone or other auto parts store and ask them to test the battery and alternator.
good luck
Jul 07, 2011 | 2000 Mitsubishi Galant
New alternator new battery installed still wont charge the battery and radio and power anttena dont work
If you have a voltage meter, you should check if your voltage regulator is working correctly. The voltage regulator should keep the voltage to the battery something under 15 volts when the motor is running (more than 13.5 volts with all electrical turned off).
If more than 14.5 volts, you may be damaging your new battery and regulator is not working properly. Also, radio may not come on because a voltage sensor is protecting it from the high voltage. Antenna is controlled by radio so that should not be working either.
Good luck.
May 05, 2011 | Buick Century Cars & Trucks
1998 ford zx2 the battery light turn on inside the dash so i took the positive wire off the battery and everything turn off know the car wont turn on i have no spark and the fuel pump dont turn on ether i...
That is a very bad way to test an internally regulated system. The alternator needs the battery to balance the load on the system. You probably just fried something by doing this because it would cause a voltage spike. Check the fuses in the under hood fuse box. The CPS could be unplugged and the fuel pump would still kick on when you first turn the key on so that isn't your issue. It is also possible you fired the computer.
Dec 30, 2010 | 1998 Ford Escort
Ok, I just got a new battery and coil ignition bwd.I also had my alternator re-built about 2 weeks ago,but my battery light still pops on when i turn the headlights on!my belts seem to be tight enuf. is it...
if you have a multi meter,
check voltage at battery with car running,should be at least 13-14 volts,
now turn on fan motor to high,flashers on,radio on, and check voltage at battery,regulator should have adjusted voltage to handle the load,should still be 13-14 volts,
now turn all that stuff off,and turn on headlights and recheck battery voltage,if below 13-14 volts replace regulator,if voltage is spiking higher than 14volts replace regulator.you do not need other belts.
Dec 10, 2009 | 1986 Chrysler Fifth Avenue
Voltage spikes and dips
Sounds like the ground strap is loose, damaged, corroded or missing.
The regulated alternator puts out 13.8 volts. 14 volts is not a spike; it is normal. If your idle is not steady, the voltage will flucuate around the numbers you are reading.
Install a ground strap from the engine to the chassis, even if the dealer doesn't want to...
hope this helps...
Sep 09, 2009 | 2001 GMC Sierra Crew Cab
Low voltage out of replaced alternator
Possible to have bought a bad alternator.... Try another one..Take advantage of the warranty the bad one came with....But have them check the voltage output on the new one so you KNOW for sure....Also consider issues with your voltage regulator and the possibility of needing a replacement. They are relatively inexpensive so that is the good news....More serious issue that could be addressed is a short somewhere in the harness. I would recommend a full electrical diagnostic to make sure there is not a bad ground....If you'd rather not spend a lot, just check all the wires you can visually.....But keep in mind that the voltage regulator is key and you do not want to spike the computer with inconsistent power levels and surges.
May 13, 2009 | 1999 Mercury Sable
Radio Communications Logo
89 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
