No start, but power supply is good
Is there a motherboard reset or fuse? Power supply checked good. Will not boot. Fans start to kick on then stop. Motherboard bad?
  • Greg
    Greg Jan 19, 2013
    Its a Dell DCMMF, hard drive is good too.
  • Greg
    Greg Jan 19, 2013
    Already figured it out, but thanks. Power supply didnt have enough power to start it up. PS checked good, but not enough amperage ... thanks though.
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 19, 2013
3 Suggested Answers
SOURCE: Dell Dimension 5100 will not power up
No doubt you've fixed this or given up by now but in the interest of helping others with this problem here is a solution. I had the same problem and it turned out to be the Front I/O & Control Panel Assembly. I suspect that the USB ports had shorted out and took the whole card down. The not turning on problem was preceded by the USB ports failing. I couldn't figure out how to bypass the card to power the computer. Dell won't help if you are not under warranty (unless you purchase some additional support). I couldn't find a replacement board on Dell's web site but found some other vendors that sold them. I bought one for about $70 and it did the trick. There seems to be at least two similar model numbers for this card. I don't know if they are interchangeable or what the differences are. If you look on the card there should be a series of numbers. Look for an "X" followed by 4 numbers. In my case it was "X8682". This is the model number for the card. If you search for shopping sites with your Dell model and this card number you should find vendors to buy the card. I think this is a design flaw having the USB ports on the same connection as the on switch. It looks like many people have had this problem. One bad usb port and your whole system is taken down. My guess is that the average user is not going to be able to figure this out and will spend lots of money unnecessarily. For those comfortable opening up the case and covers (you can download the manual from the Dell site) and unplugging ribbon cables this is a fairly simple fix. Keep in mind the card won't come with any instructions. Make sure you follow power safety rules and ground yourself.
Posted on Jan 12, 2010
  • 3940 Answers
SOURCE: Dell Inspiron 530 won't start up - is motherboard dead?
From your description, I agree with you assessment of a likely Motherboard failure.
Posted on Mar 09, 2010
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
Power supply is good, fans running - no display on
make sure to check the video cable (DVI,VGA,HDMI) if properly connected
if youre using an independent video card and your motherboard has a builtin try to use the integrated to check if the video card is faulty
if you dont have a video card and using the integrated the motherboard might be faulty
Jul 20, 2010 | Asrock P4I45GV R5 Motherboard
Won't boot....fans start, then stop right away
check if your power source is ok. it may be broken and this is why you hear the fans start and then stop right away. they are working about 3-4 seconds, aren't they?
remove and put back the jumper for clear cmos after you test your motherboard with a new ac source
Jan 25, 2010 | Biostar P4M900-M4 Motherboard
PC doesn't boot up.
Use jumper to reset cmos. Test or replace cmos battery.Unplug evthing( HDD,CD,DVD,FLoppy) try to start barebone. Test voltage from power supply to motherboard. Try different ram. Good Luck.
Nov 21, 2009 | EliteGroup Lga 775 GF7100PVT-M3/MCP73T-M3...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
PC wont start/boot
hello...i think you need to check all socket connection on the board and you need to check the memory or try to reset the Bios.or check the ATX power supply it is good or working..thank you
May 08, 2009 | eMachines D3415 PC Desktop
Computer does not boot
If you computer over heated, this could have caused the board or power supply to short. I would first start by trying a new power supply unit (since this is cheapest of the options). If that does not work then try replacing the motherboard and/or processor. Since you not getting any power, my guess is motherboard or power supply unit.
Apr 20, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Intel 210882 mother board power won't spool up fans or anything.
usually power supplies comes in different voltage n wattage . check ur mother board manual that which type of powre supply it support than replace it with the good one.it may solve ur problem.thanks
Apr 17, 2009 | Intel Motherboard
Gateway 831gm not booting. Fans come on but no boot process.
2 questions:
When you say new motherboard do you mean an actual new motherboard or new to that machine, but came from another used model?
When you say you tested the power supply do you mean with a voltmeter/ammeter or put it in another computer and it worked?
I worked on several gateways with similar problems and it boiled down to motherboard issues.
I tested it by replacing the power supply with a bigger (used) power supply and it worked great (for 1 time) and then put the other power supply back in to confirm my diagnosis and yep it wouldn't boot. The next morning I was going to run some virus/malware cleanup and installed the other (known good) power supply and it would not work. I tried all day to get it to boot and it did about twice in a 4 hour period. When it did run it would run great but any attempt to restart it would cause it to crash. No ryhme or reason, it would not fail the same way more than twice. Sometimes beeps, other times no beeps, sometimes it would start up with no video (could hear the Windows starting sounds) other times it would start up normal. I could let it sit and it would start or I could keep trying in sucession and it would eventually start. Some times the fans would slow down from a roar, sometimes they wouldn't. So with a known good power supply that had 150 more watts than the original I diagnosed it as a failed motherboard. But if you have put in a brand new motherboard then I would replace the power supply, because a bad power supply does not mean no power, just not enough power. Please post back and let us know what you find out.
Mar 31, 2009 | Gateway 831GM PC Desktop
Boot Issues
I've seen the same problem fixed it with new power supply. The old one was losing full power.
Oct 08, 2007 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Computers & Internet Logo
David Payne
David Payne
