Control seems to be frozen mid wash cycle. Paused the wash cycle to untangle drum contents. Control seems to be frozen. No response to any buttons. Showing error message "Sud". How do I get it to
  • Jane Jan 19, 2013
    Model GHW9200LW
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Model number?
Posted on Jan 19, 2013
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
SOURCE: Samsung Big Wash B1215j -
error code e2 comes up what does that mean
Posted on Jul 23, 2008
SOURCE: GE Front load washer WCHVH 6260F
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
Posted on Jan 26, 2009
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
localwonder
  • 6784 Answers
SOURCE: Sears kenmore washer 110.42822200 error code sud
SUD- Suds lock (Overdose of detergent detected during the wash cycle, or the actual brand is a non HE type)
The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Possible Causes / Procedure
• If too much detergent was used:
A. Run the unit through a Rinse/Spin cycle.
B. Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent. If the problem persist, follow this check list below.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Press PAUSE/CANCEL twice to clear the display.
Posted on Dec 07, 2009
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
Hello, I have a Frigidaire model LTF7000ES0 and it is frozen. I was washing a very small load and paused it to add more, when i closed the door and pressed the start button it gave me three quick beeps and...
Unplug it for 10 minutes. Plug it back in and see if it starts and runs normally. If it doesn't then I'd suspect the pressure switch first then the control board.
May 10, 2017 | Frigidaire Affinity ATF7000E Front Load...
sorry have no info on this model have you tried draining the mach manually then switch it back on i have seen this type of prob on other makes main control board is sometimes required
May 07, 2014 | Washing Machines
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Why would it stop mid cycle? You can hear the engine trying to start.
It is not the engine but the motor that makes the noise. perhaps it can be a mechanical issue that stops the machine at mid cycle due to friction on the drive or it can be due to faulty control panel or even a dirty/ clogged drain pump.
Sep 07, 2012 | Fisher and Paykel Washing Machines
I paused it but now its frozen
checker timer, you may have shorted it out when you stopped the cycle short. Not your cause as it would have happened any way
Mar 08, 2010 | KitchenAid KHWS02R Front Load Washer
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Washer shakes real bad in spin cycle
Does it do this when the drum is empty?If not, then you may be overloading the unit with clothes. Or, the clothes may have entangled into a ball. Untangle and spread out.
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Machine stops mid cycle
Replace your control button(Start button).
Jul 22, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
