Question about Dell Latitude C640 Notebook
Limited or no connecctivity
I have connect to the inter net. But i can't share the inter net to another computers. Because the "Local area connection" showing limited or no connctivity. Please solve my problesm.
  • rkcomputers_ Jan 26, 2009
    tell me at least reason for this problem.
    Genius:
  • Dell Master
  • 1,102 Answers
Right click icon in taskbar then wireless connection
a connection should show highlight and click connect
if no connection shows on left side of page click refresh list you may need to do this a few times when a connection shows high light click connect
Let me know if this has helped if not you can do a connection repair
you may also want to update driver in device manager
Posted on Jan 26, 2009
  • DEKR
    DEKR Jan 29, 2009
    has this helped or do you need more help
    don't forget to rate me thanks
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    Wired nor wireless connections for my ps3 wont work
    if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
    and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
    If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
    Sep 20, 2009 | Sony Playstation 3 (PS3) Console
    I have have a proble which has realy disturbed me
    open network connections in control panel in that right click " Local Area Connection " . In the bottom of the pane you can see this option " Notify me this connection has no connectivity or limited " Uncheck this option ... this solves your issue.
    Aug 27, 2009 | Microsoft Windows XP Professional for PC
    How do i build a local area network in windows xp?
    On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
    Dec 02, 2008 | Computers & Internet
    D-link cant accesed internet 4pc
    Most of DSL modems are connected to PC with USB cable...
    n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
    Following are the steps to enable Internetsharing for other pcs.
    How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
    On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
    1. Log on to the host computer as Administrator or as Owner.
    2. Click Start, and then click Control Panel.
    3. Click Network and Internet Connections.
    4. Click Network Connections.
    5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
    6. Click Properties.
    7. Click the Advanced tab.
    8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
    9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
    10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
      address 192.168.0.1. Your computer may lose connectivity with other computers on
      your network. If these other computers have static IP addresses, it is a good idea to set them
      to obtain their IP addresses automatically. Are you sure you want to enable Internet
      Connection Sharing?
    11. Click Yes.
    The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
    let me know if it helps.
    best regards,
    Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
    Laptop and Desktop Pc connecting to internet
    If you have a local area network inside. All you need to share files. Find the other side of the IP can be. For example: / / 192.168.0.1 so to be able to jump out of a password. On the note in order to succeed.
    http://www.notebooks-driver.com
    Nov 03, 2008 | Computers & Internet
    Limit or no conectivity problem
    I understand that you are using the Windows Internet Connection Sharing to share your internet connection to your other computer.
    If you don't have a router to share the connection then you are using Windows ICS connection.
    When you enable ICS, the network adapter connected to the local area network is assigned a static IP address of 192.168.0.1.
    You can check this site for more information
    http://www.annoyances.org/exec/show/ics_xp
    You can try to connect the two computers first without the internet connection.
    Example : PC A 192.168.0.2
    You can set the IP addresses manually, just set the tcp/ip properties and from that area you can set the IP address manually.
    And for PC B 192.168.0.3
    You dont need to set the ip address for the gateway and dns since you are just testing the connection of the two computer.
    They should belong to the same workgroup example HOME and set the computer name to PC1 and PC2.
    You can right click MY COMPUTER then select PROPERTIES then you will able to see the computer name.
    To start the wizard
    1.
    Choose Control Panel from the Start menu.
    2.
    Click Network and Internet Connections, and then click Set up or change your home or small office network.
    http://www.smallbusinesscomputing.com/webmaster/article.php/3293481
    http://www.homenethelp.com/connection-sharing.asp
    http://practicallynetworked.com/sharing/xp_ics/
    Mar 05, 2008 | Computers & Internet
    Dell Latitude C640 Notebook Logo
    189 people viewed this question
    Alun Cox
