Question about Garden
How do I set electrodes on a power america 1422 steam pressure washer
Low pressure
It sounds like the nozzle is worn or the wrong size ( too big )
Oct 23, 2014 | All-Power America Steele Products SPWE175...
I need the carburetor
Apache does not sell units. please consult where you purchased this unit from.
Nov 16, 2013 | ALL POWER AMERICA LLC All Power America...
How do i install my soap dispenser into the 1600 all-power electric power washer
There should be a 1/4" hose nipple on the pump which will connect to the soap dispenser with a 1/4" line.
Sep 28, 2013 | All-Power America Garden
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
My vicks vaporizer is not blowing steam is it suppose to. rfinson30@yahoo.com
This vaporizer has two carbon electrodes covered by a 3in black cylinder with a couple of recessed phillips screws that take a narrow long shaft phillips screwdriver. Those two carbon electrodes are about 3/4 inches apart, and the water + a sprinkle of salt set up a resistive path between the electrodes that produces a boiling action on the water, thus steam.The electrolytes in the water, (calcium, iron, magnesium) eventually create a bridge between the electrodes, that allows the voltage to cross the electrodes without heating the water. You would have to take the cylinder off and scrape the built up electrolytes off of the carbon electrodes and reassemble the device, but you can buy another for about 15 bucks, but the same thing will happen again. If you try to use a little less or no salt on the next one it will last a lot longer.
Feb 03, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Engine runs fine, pump works, but it's not kicking the burner on ?
The first thing I would check is spark on the electrodes in the burner, if you pull the transformer down from the bottom of the burner you will see two springs that touch metal poles in the bottom. You are going to have to have someone else run the machine in cold water mode (these machines will create spark in cold or hot water mode) and holding onto a long insulated screwdriver you are going to get about 1/4 inch away from each of the springs and see if a spark comes across the spring and the screw driver. Be very careful in doing this, you are playing with a lot of power. If no spark then this would indicate that you have a fuse blown or the transformer is bad. You would then proceed in checking power to the transformer. If you are getting spark then it is going to be one of the safety systems that is giving you a problem. Let me know what you find out.
Oct 27, 2010 | Northstar Wet Steam & Hot Water Pressure...
Won't heat
sound like its not getting a spark at your electrodes.
Apr 07, 2010 | Northstar Electric Wet Steam & Hot Water...
Steam cleaner smokes likes mad
the air fuel mix is not correct. the coil is blocking the air intake. fuel nozzle not pointing into the combustion chamber?
Dec 13, 2009 | Karcher Garden
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
