Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
Anonymous Posted on Jan 19, 2013
Click no display clicks when powered on
Can power saver be turned off ?
Yes, you can turn off the power saver feature on your display. The steps to do so may vary depending on the brand and model of your display. Here are some general steps to disable power saver on a monitor:
  1. Right-click on the desktop and select "Display settings".
  2. In the Display settings, click on "Advanced display settings".
  3. Click on the "Monitor" tab and look for a "Turn off display after" or "Power saver" setting.
  4. Change the setting to "Never" or disable it completely.
If you are using a KVM switch, it may also have a power-saving feature that is causing the display to power off. You may need to check the manual or the manufacturer's website for information on how to disable the power-saving feature on the KVM switch.
If you are using the Microsoft Win 10 "project" feature, you can adjust the display settings by following these steps:
  2. In the Display settings, click on "Project to this PC".
  3. Look for a "Turn off display after" or "Power saver" setting and change it to "Never" or disable it completely.
These steps should help you disable the power saver feature on your display and prevent it from turning off. If you are still having trouble, please provide more details about the brand and model of your display and KVM switch, and I'll do my best to help you further.
My Acer 5583 laptop will not turn on
Acer notebooks with the Windows operating system installed give computer users the ability to set power-saving options. For example, with Standby or Sleep mode, the computer will turn off certain battery-consuming features and save all open files in memory. If Hibernate is enabled, after a period of time, the computer will turn itself off after it saves all open files to the hard disk drive. You may save time in troubleshooting by first verifying the settings that control how your notebook powers on and off.
1. Press the "Power" button to turn the computer on and recover from Hibernation or open the lid of the Acer notebook to awaken it from Sleep mode. If your computer does not power up, continue.
2. Click the "Start" button, click "Control Panel," and then click "System and Security."
3. Click "Power Options" and then click "Change plan settings" on the "Select a power plan" page.
4. Click "Change advanced power settings" on the "Change settings for the plan" page.
5. Double-click "Sleep" on the "Advanced settings" tab and then double-click "Sleep after."
6. Click one or both of the "On battery" or "Plugged in" options and then click the arrow.
7. Click "Never" and then double-click "Hibernate after."
8. Click one or both of the "On battery" or "Plugged in" options and then click the arrow.
9. Click "Never" and then double-click "Display."
10. Double-click "Display" and then double-click "Turn off display after."
11. Click one or both of the "On battery" or "Plugged in" options and then click the arrow.
12. Click "Never," click "OK," and then click "Save changes." If you still experience problems, visit the Acer website and check if updated drivers are available for your Acer notebook. The link is listed in References.
I hope you find it very helpful. Thank you for using fixya.
I am tying to charge my ipod but my laptop but ifi am not using my laptop for more than15 mins. how do i get my laptop to stay on while i am not using it
Go to help or control panel and type in 'sleep and hibernation faq' and follow the 'power options' to the directions to keep the computer from sleeping and hibernating.
You can adjust how long your computer waits before sleeping or
hibernating-or prevent it from turning itself off altogether. But be careful. On
a battery powered laptop, inhibiting sleep or hibernation can result in data
loss if the battery dies. Here's how to prevent your computer from entering a
power-saving state:
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Power Options.
  2. On the Select a power plan page, click Change plan settings next to the selected plan.
  3. On the Change settings for the plan page,
    click Change advanced power settings.
  4. On the Advanced settings tab, double-click
    Sleep, double-click Sleep after, and
    then do one of the following:
    • If you're using a laptop, click On battery
      or Plugged in (or both), click the arrow, and then click
      Never.
    • If you're using a desktop computer, click Setting, click the arrow, and then click Never.
  5. Double-click Hibernate after, and then do
      Never.
  6. If you also want the display to stay turned on, double-click Display, double-click Turn off display
    after
    , and then do one of the following:
      Never.
  7. Click OK, and then click Save
    changes
Change operating system from Spanish to English
Im assuming that the question is the operating system, commands, etc are all in spanish. You did not specify your operating system so unsure about what version or manufacturer. The instructions below will work for Vista... similar instructions can be done in XP and Win 7.
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
  4. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  5. Click the Keyboards and Languages tab.
  6. Under Display language, choose a language from the list, and then click OK.
  7. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  8. Click the Keyboards and Languages tab.
  9. Under Display language, choose a language from the list, and then click OK
2answers
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Toshiba X205-SLi4 went through one of those updates where it has to do 1 of 3, 2of 3 etc configurations. Then it rebooted and now we have no monitor. You can tell it is on, but nothing comes upwhen the...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used?3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status").7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Toshiba L10 display will not work.have pressedfn+f1 and fn+f5 but to no avail.
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?). 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Remaining Batter Power is not displayed in Power Meter
Go to control panel and click on Power Options.
Click on advanced and check if icon display on task bar is enabled.
Click OK
Also in the power meter icon click on the battery icon s if you are using 2 batteries
3helpful
Hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
