Question about Garden
The chain is turning very very slowly when revving.
  • 1,807 Answers
Chain brake may still be applied, thus the clutch is fighting adainst the brake band.
Brake handle is the front hand guard, tru pulling back to its off position.
Posted on Jan 19, 2013
The sprocket in front of the bar is ither broken or it needs a good cleaning and oiling it has happened to me
Posted on Feb 13, 2013
Stihl o25 tension fluctuates
check the clutch side ,crank berring to see if there is play,if there is play you have to replace
May 04, 2014 | Stihl Models 064, 066, Ms640, Ms660
My pgo pmx 50 problem started with the electric starter appearing to bind or turn slowly , this then continued to my indicators only working under high revs and when combined with a brake light they fail...
Yes, voltage shouldn't go any higher than 14 to 14.5 volts when running, even when revved up. If it's reading only 12 volts at idle, regulator is faulty.
Aug 25, 2017 | Cars & Trucks
Stihl 023 runs OK but the chain does not turn
Since that is a centrifugal clutch, the speed of the engine is what turns the sprocket. If it revs good and doesn't turn then I would have to assume that the clutch is not making contact with the drum, the chain brake is on, or it really isn't revving the way you might think it should. If it is a clutch issue then it should over rev.
Jan 16, 2013 | Garden
Chain doesnt turn
It may be the chain brake has activated, grab the front hand guard and oull it firmly fully back to the top handuntil you hear an audible click, now try again.
Apr 30, 2012 | Garden
My bike chain clicks when it goes round the chain adjuster wheel, what's the problem?
Without seeing it, I would guess that you have a stiff link. Try turning you bike upside down and watch your chain as you slowly turn your cranks. When you see a link raise up, try working the chain links with your fingers on each side to try and loosen it up, Otherwise you have to have a chain tool and take it off of the bike and just replace it.
Sep 28, 2010 | Cycling
I have a stihl chain saw which although only 3 years old has not been used for 2 years. It started first pull but the cog that drives the chain will not turn and smokes when revved. Is there any easy cure?
remove chain and bar and start up saw if gear turns and revs up than oil bar and chain// if not safety/kickback may be holding back adjust,reset or clean if sticking-- clutch sticking repair or replace
Jan 25, 2010 | Garden
Homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Oct 06, 2009 | Garden
Briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Jul 01, 2009 | Champion International Champion& Small...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
