Question about FUJIFILM FinePix J30 Digital Camera
Connect to mac - FUJIFILM FinePix J30 Digital Camera
    Genius:
  • 1,669 Answers
Try this website:
http://www.fujifilm.com/support/digital_cameras/compatibility/mac/
Posted on Jan 19, 2013
A connection between a westinghouse hdmi to mac 11'. i have a cable but now TV works just not the connection to the mac. mac works.
OK, Sylvia Miller, let me see if I got the question correct.
You are having a problem when you connect your Mac (have no idea which model thou) to your TV, and your TV is not showing, or mirroring your Mac, is that correct?
If this is what you mean, I'll post some guidelines to follow.
1. Make sure that the port you're using to mirror the Mac match from input of the TV. It means that if you connect the cable to HDMI 1, the go to your TV menu, press input or source in the remote control and take it to HDMI 1.
2. If the TV recognize the connection, on the top bar of your Mac you should notice a triangle, when you click on it, you will have the option to activate mirroring. If there is no triangle the it means that the TV did not recognize the connection from the Mac.
3. Tweak and mess around with the Thunderbolt cable. These cables are far from perfect. Once you plug it in, move it around, some times it does;t make a very good connection.
I think that's just about it. Best of luck.
Sep 22, 2015 | Westinghouse Televison & Video
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
How do I connect my MacBookPro to my I Mac to transfer photos and music?
  1. Connect the Thunderbolt cable to the Thunderbolt ports on each computer.
  2. OR
  3. Connect the Mini DisplayPort cable to the ports on each computer.
  4. To change display settings, choose Apple menu > System Preferences, then click Displays on the primary Mac.
Oct 03, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Connecting samsung montage to internet using mac powerpc internet connection?
does your mac support bluetooth hotspot ...
there are a few wifi hotspot programs for windows pc but Iam most ceetain macs don't
Apr 17, 2017 | Samsung SGH Cell Phones
How can i transfer photos from evo to mac pro?
Try following this steps, leads you to know how to sync HTC with Mac?
1. Set HTC
Press HOME > MENV, and choose Setting > Applications > Development.
In the Interface of "Development", you must make sure all check boxes are selected include "USB debugging", "Stay awake", "Allow mock location".
2. Connect HTC to Mac
After setting, connect HTC phone to your Mac with USB cable. Then you can see "USB Connected" in HTC. Only need to Click it and choose "Mount". HTC (HTC Aria, HTC Evo 4G, HTC HD, etc) will connect with your Mac as a disk drive.
3. Sync HTC with Mac
Then you can transfer compatible media files such as music, movies, photos between HTC and Mac through drag and drop.
Nov 26, 2010 | HTC EVO 4G Smartphone
Just bought Mac with os x 10.6.1 and i want to bring my address book over from Outlook in Windows xp.
To move files by connecting your Mac directly to your PC:
  1. Connect your Mac to your PC using a standard Ethernet cable.
  2. Make sure that both computers are turned on.
  3. In the Finder on your Mac, choose Connect to Server from the Go menu to open the window.
  4. Type your PC's network address in the Server Address text box using one of these formats:
    • smb://DNSname/ShareName
    • smb://IPaddress/ShareName
  5. Click Connect.
  6. Follow the onscreen instructions to enter your PC's workgroup name, user name, password, and the volume or folder you wish to access.
  7. Your PC volume should appear on your Mac Desktop.
  8. Open the volume and drag and drop files directly from it to anywhere on your Mac.
  9. When finished, drag your PC volume to the Trash to unmount it.
Nov 03, 2009 | Apple Mac OS X 10.4 Tiger for Mac
How do I connect my Samsung Jet to my Apple Mac running Osx 10.5.8 for using it as a modem for internet connection.
If your Mac has Bluetooth, you can connect to the phone via a bluetooth connection and use it as a modem. You first need a connection profile on the phone that will allow an IP connection (data) to your phone network, either via 3G or GPRS, though the former is potentially faster.
Then you need to Go into system preferences->Network on your Mac and create a Bluetooth connection profile that may need a user name and password to connect to your phone networks data access point.
Then select the IP profile on the phone, turn Bluetooth on. Turn on Bluetooth on the Mac and select the Bluetooth connection profile in Network on the Mac and click on the connect button, it should then connect and away you go
Oct 23, 2009 | Samsung Jet S8000 Cell Phone
How to connect new apple macbook to belkin G Plus
You do not need a compatible driver for use with the Mac. Reset the Belkin to default, then tuen your Mac on. The airport should see the wireless network and connect
Sep 02, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Connecting another Mac to a laptop
Connect the 2 with a firewire cable. Reboot the Mac you want to read from & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The other Mac should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
FUJIFILM FinePix J30 Digital Camera Logo
27 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
