Question about Philips HTS8100 Theater System
Connect HTS8100/37 connect to TV
    Genius:
  • 1,669 Answers
Try this web site:
http://search.aol.com/aol/search?&s_qt=sb&q=Philips+hts8100+owner%27s+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
or:
http://elektrotanya.com/philips_hts8100.pdf/download.html
Posted on Jan 19, 2013
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Tv screen tells us we are not connected to internet.
Hello Ralph
Have you configured your TV to connect to internet? You would do this by Going to your Settings and typing in the password for your router or your internet provider.
If you have your TV manuel that should also tell you how to configure your TV...and is the TV a "smart" TV? Connecting to internet only works if you bought a smart TV.
If not you can connect a laptop that is connected to your internet and connect that to the TV with an HDMI cable.
Hope this helps
Feb 09, 2015 | Netflix
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
Excellent picture but no sound
This problem has 3 possibilities, that your tv audio output is already damage or the cables that connecting to your tv and digital reciever is loosed or damage and may be your digital reciever sound pre amplifier is damage. Let's start to your tv, try to use a dvd player or cd player and connect it directly to your tv audio video input, or you can remove the connection from the digital receiver and use a small piece of wire then connect it to your tv antenna input and set your tv mode to aerial tv.If the tv produces sounds your tv is ok. To wire connection, first try to check all the cables that connecting to your tv and digital receiver specially the input, output connection,If wire is ok. Then the digital receiver has the problem try to contact service provider and ask if your digital receiver has a warranty.
Jul 16, 2011 | Samsung 50 in. TV
When I turn sony kdl32m4000 on, green power light comes on but
I understand that your TV is turning ON but you're not bale to view the videos on the TV screen. If the TV is connected to a wall outlet through a Surge protector please disconnect the connection through the Surge protector and try connecting the TV to a working wall outlet and check if that helps. Please check the connection between the TV and the connected device. Please try using a different device and check if that helps. This is to check whether the issue is with the TV or the connected device. Please try to explain the issue as much as you can next time. What are the video sources connected to the TV? Does this issue occur with the TV when connected to other devices? How did you connect the videos sources to the TV? Which connection are you using to connect the devices to the TV? You TV doesn't support 1080p resolution, so please check whether the connected device is giving output in 1080p resolution. If the issue still persists service of the TV is recommended.
Jun 16, 2009 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Wireless headphones
you need a stand alone tv tuner with audio/video out
how to install:
1. connect tv antenna to tv tuner
2. connect tv tuner video out to tv
3. connect tv tuner audio out to your wireless headphone control tower.
Fixya... GOOD DAY!!!
Sep 14, 2008 | Computers & Internet
Philips HTS8100 Theater System Logo
89 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
