Question about Desa International Reddy Heater® RHERH125AT
Wire hanging in heater
A red wire hanging inside control mechanism on a Reddy Heater 152828 Model #R150. we need a schematic on the wiring to fix it.
It would help if you could find a users manual. Please le me know.
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: reddy heater r35
no it doesn't - the ignitor goes to printed circuit connectors on your control board. the ignitor operates on 120 volts ac. for repair parts on any reddy heater go to www dot desatech dot com
Posted on Nov 10, 2007
  • 19 Answers
SOURCE: troubleshooting reddy heater 115,000btu
Remove the nozzle and clean it. Clean the photo cell also. Check the fuel pump pressure it should be 5.1 #.
Posted on Mar 06, 2008
SOURCE: reddy heater won't stay on
Just go to Tate Heater repair shop for heaters and replace the Thermal Switch. The part number for the Switch is 113848-01. See if they have one if not they can order it for you. I just fix mine and it is now it purs like a kitten. Just the way the manufacture intended. I went also went down the road of buying a new thermocouple to find out that I did not need it. My advice change the less expencive Thermal Switch first in your part replacement list.
School of hard knocks
Posted on Oct 17, 2008
tbugger
  • 232 Answers
SOURCE: REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Posted on Dec 16, 2008
tbugger
  • 232 Answers
SOURCE: The heater shuts off tripping the reset- motor/fan ***'y is froze
097134-02 try Reddy Parts
Posted on Dec 23, 2008
Do you have a wiring schematic for this heater board? some i believe has jack with wiring tryingto by pass a problem!
go to Desa.com enter model# and it will the manual,I don't believe they could that each wire connection are diffance size. The control board is marked for connection. Ken's Repair
Jan 18, 2011 | Reddy R115DT Oil Filled Utility Heater
I have reddy heater 35000 btu.starts ,then works 5 seconds and shut off
I have a LP gas version. I had to disconnect some kind of sensor (looks like a watch battery with 2 red wires). I made a jumper wire and put in place of red wires. Works fine now. This sensor might be an Oxygen sensor.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Jul 16, 2010 | Heating & Cooling
Reddy heater blows the fuse in the control panel,
Check out on the nameplate on Reddy Heater how many amps it draws and what size circuit is needed.
It could be that you have an undersized wire and outlet where heater plugs into
Jun 18, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater R55 concerns
They are grounds, and should have two screws on the burner tray to hold it from moving. On my heater this is where the grounds get attached. It gives the igniter a dedicated direct ground.
Jan 10, 2009 | Reddy Heater-30-55,000 BTU Variable
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Reddy heater r35
Nov 08, 2007 | Reddy Heater-30-55,000 BTU Variable
Desa International Reddy Heater® RHERH125AT Logo
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Gil Shultz
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
