SOURCE: distributor cap firing order 1993 chevy cheyenne truck v6
Firing order is 1-6-5-4-3-2 cyls. # 1-3-5 on drivers side front to back and cyls. # 2-4-6 passenger side front to back.
SOURCE: 1990 chevy 350 distributor wiring diagram and firing order
The firing order is 1-8-4-3-6-5-7-2.
The distributor rotates in a clockwise direction. The engine must be on the compression stroke on the #1 cylinder. Line up the timing marks. Remove the cap and the rotor should be pointing to approximately the 5 o'clock position.
Good Luck
SOURCE: 1998 Chevy Truck 1/2 ton 350 engine. Trouble codes
404 is exhaust gas recirculation circuit, and 405 is exhaust gas recirculation sensor circuit low. EGR sensor or ground?
SOURCE: firing order diagram for 1999
For the 1999 Chevrolet WITH 5.7L V8:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
.........(back).........
'...8...'........'...7...'
'...6...'........'...5...'
'...4...'........'...3...'
'...2...'........'...1...'
.........(front)
Distributor Connections:
............(back)
Coil--->o
6------->o........o
4------->o........o
2------->o........o
8------->o........o
.............(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact us at FixYa.com!
