Question about GE DPGT750GC Gas Dryer
When I screw cord to dryer it will shock when I touch
I hooked up the drywer cord to the dryer and it works but if I touch one of the screw connections. it will shock me is thaty normal
    Genius:
  • 2,920 Answers
Yes its normal,,,,you dont touch them after you hook it up they will shock you
Posted on Jan 26, 2009
Is the grounding strap necessary for GE profile dryer
no-- but if you want to avoid electrocuting it would be a good idea to hook it up
Jan 24, 2016 | GE Dryers
I have a kitchen aid dryer and there is a lil ground cable in the back of the dryer...wat is for?
Hi raider omar8...
That little ground (normally green) wire should be hooked up to a ground in your house...either a water pipe,grounded screw on the receptical, etc.
It keeps you from being shocked if your barefoot and wet while touching the machine.
Please take time to rate me
Jul 18, 2011 | Dryers
My kennmore dryer isn't working and giving me
Hi, The plug is not hooked up right...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
May 08, 2011 | Kenmore Dryers
The Dryer won't run. No power at contols at the top of the dryer. Getting shock if you touch the dryer and you are grounded. Example : If I take my multimeter and touch one probe from the dryer cabinet...
Need to open the panel and inspect inside the dryer. Obviously the power cord is not a problem, but some wires connecting to the circuit board panel got loose then caused such a problem. Use the volmeter and follow the schematic to check the proper terminals.
Sep 20, 2010 | Dryers
Its shocking me when i touch it.its not static its electric
you have a short to ground(you should never get a shock that way(get someone to test your house grounding system) your element may have broken and is touching the frame and give you 110 volt zap not fun hi hi
Aug 24, 2009 | Dryers
How to install a 4 wire cord on a 3 wire dryer
This is a common question we receive and a common mistake most every general contractor makes that we work with. With a 3-wire system your neutral terminal will have a copper clad or aluminum strap or green wire connected between it and the frame. You need to remove this when changing to a 4-wire cord.
Terminate the wires from your new 4-wire cord as black to black terminal, white to white terminal, red to red terminal and green to ground screw on frame. This is the other end of that strap or green wire you need to remove from the white (neutral) terminal.
When changing to a 4-wire cord it is very important to remove the strap or wire that connects between the white terminal and the dryer’s frame. If you do not remove this, your neutral or grounded conductor will allow electricity to flow through your dryer’s frame and shock you each time you touch your dryer.
Jul 15, 2009 | GE DCSR483EA Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Where to wire the ground when changing a three prong to a four pr
This cover is all different sizes and shapes depending on the manufacturer of the dryer, but it is typically very close to where the cord enters the dryer. The cover is typically held in place with 1 - 4 screws. See image to the right of a Maytag Performa dryer access panel.
04b796a.jpg With the cover open you will see a terminal block with three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nutdriver to remove the nuts or a phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Now you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
If you do not have the original bonding strap, you can make one. You need a short piece of green 10 AWG wire, 2 ring terminals, a pair of wire strippers and a pair of crimpers. Strip both ends of the green 10 AWG wire and crimp one ring terminal onto each end of the wire. Now connect one end of the wire to the neutral (center) terminal and the other end to the dryer’s frame; where your ground is connected now. a9fc1b2.jpg Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. To hook up your new 3-wire dryer cord, connect each wire to the dryer’s terminal block. The 2 outer wires are your “hot” wires and the center wire is the neutral. Replace the access panel cover and your new 3-wire dryer cord is installed Before plugging in your new dryer cord, I recommend turning off the breaker to your dryer receptacle. Then plug in your dryer. Now turn the breaker back on. This is not fool proof, but it is a safer way to turn on the power to your dryer if you made a mistake connecting your new dryer cord.
If your dryer is different from the one described above and would like a second opinion on your connections, email a picture of the terminal block to info at ezdiyelectricity dot com. I will post the pictures on this page to help others with the same dryer.
Apr 05, 2009 | Whirlpool LER4634J Electric Dryer
Electric dryer no heat and eletricut
ck where ac cord is attached to dryer suspect burnt connections on terminal block ..or loose wire touching cabinet if block is burnt probably due to loose connection when screws were not tightened during install
Nov 20, 2008 | Kenmore 73952 Gas Dryer
4 wire power cord connection
The difference between a 3 and 4 wire cord is the 4 wire cord separates the ground and neutral, where the 3 wire grounds through the neutral. The 4 wire cord gives an extra safety against electric shock. The red and black wires on the cord go to the red and black wires on the terminal block. Then you have to determine where the green wire on the dryer goes, if it has one. Some dryers have the green wire spliced into the white wire maybe 6 inches from the terminal block. If this is the case you will hook both the green and white wires on the dryer to the nuetral (middle) terminal with just the white wire on your cord. Some dryers have a ground strap, a flat narrow peice of metal that goes from the neutral of the terminal block to the cabinet just below it. If this is the case then remove the screw securing it to the cabinet and bend it back up onto the nuetral terminal, or remove it completely. Then hook the green ground wire from the cord to the cabinet of the dryer. Make sure all of your connections are tight, but be careful not to strip them. It's also important to hook up the strain relief to prevent any possible tugs on the cord from pulling on the terminal block connections.
Jul 21, 2008 | Hotpoint Dryers
Open Questions:
Dryer is acting up. so, it hasnt been used in about 2 months.  it sat out in a cold garage.  but was back up to 'room temp' when we hooked it up.  the gas line is secure.  the venting is proper.  the dryer's level.   after turning it on, not much has happened.  a faint 'beeping' signal comes out of it every few seconds or so, and signal lasts about 2 secs.  the dryer will tumble and kinda gets a weak luke-warm.  i heard this clicking (blower motor i think) as if it were a rotating clicking noise.  then i heard what sounded like a piece of plastic drop.  then poof! the blower kicked on and the dryer started crankin'! working great.  thought maybe something needed to settle.   note* i did have this dryer on its side while moving it in the back of my pick-up truck.  (which was covered from the elements w/ a cap & laid on soft blankets).* after several uses some serious noises started coming out of it.  a severe clicking rotating plastic thumping, sounded like hard plastics banging, clicking rotating, hard to explain.. i reset the dryer.  now it starts up, and just rotates, blower never kicks on.  doesnt really get hot, back to a weak luke-warm.  (i threw a wet towel in there..nothing, no heat/blower)  nothing going through the vent either.  so..i was thinking about pulling the back off, but figured i'd ask you guys first. also, do you think it's worth it to call in a Sears professional?  costs involved?   yeah man, any help would be appreciated, the thing's out of warranty, and well..i need a working dryer, full household.  laundry piles up!   - thx, Angelo
Feb 28, 2017 | GE DPGT750GC Gas Dryer
GE DPGT750GC Gas Dryer Logo
217 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
