Question about Whirlpool Refrigerators
I have a whirlpool refrigerator model m#g17fvcxwy01 and the inside lights and water and ice maker stopped working. How do I fix this problem?
Refrigerator is stainless steel with french doors and is computerized
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
I don't get any results on that model number. Could you please double check it for me?
Thank you!
Posted on Jan 20, 2013
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
mikedurland
  • 481 Answers
SOURCE: I have a GE Profile
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 01, 2008
peyton32034
  • 410 Answers
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Posted on Jan 28, 2009
  • 10865 Answers
SOURCE: My Whirlpool refrigerator Model # ED5RHEXNL00 Ice maker broken
Hello. Thanks for choosing fixya! The most common cause for your problem is that someone accidentally raised the wire in the icemaker area that turns it off. Check that first if the wire is up, push it down and within a few hours you will have new ice. The second most common problem is that the cubes in the mold got stuck in there. the fix is to use a blow dryer to free them up, then dry out the mold and spray some PAM cooking spray in to the mold to lubricate it. The final possibliity is that there is ice in the water supply line that feeds your ice maker. Once again get out the blow dryer and thaw that ice so that the water flows once again. good luck with it. regards, joe
Posted on Nov 05, 2009
  • 8 Answers
SOURCE: Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Posted on Mar 25, 2010
Our Whirlpool refrigerator model ED5SHAXMB10 is keeping our freezer food cold, yet no cold air is being blown into the refrigerator. Refrigerator is getting very warm. What can be done to fix it?
The defrost is not taking place on time or the defrost ventilation door is stuck closed.Its controlled by motor,that motor is got faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
My Whirlpool refridgerator has water in it. Where could it be coming from and how do I fix it.
Water must be getting melting from freezer section/.See if over ice is getting collected in freezer vents and freezer walls.
These will help.
Thanks,.
Dec 21, 2012 | Whirlpool Refrigerators
It just stopped making ice yesterday. A question.
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
I have a Whirlpool Refrigerator Model 25SSA made in 9/05. SN: ED5NHAXN001 The ice maker just stopped making ice.
OK there could be several things to cause that. The dual water control valve is defective. Ice blocking the fill tube leading to the ice maker. Thermostat inside the ice maker. When the ice maker stopped what position was it in? Let me know and I will help you. Sea Breeze
Jun 21, 2009 | Refrigerators
Ice maker not working ; water dispenser ok
The reason could be several different possibilities. the water control valve for the ice maker no longer works or one of the many components inside the ice maker is needing replace or adjusted. Go to link below and enter model ED5VHGXM into model search. Click on photo #12 ice maker and you get a breakdown of of all the parts. Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Ice maker working, water stopped dispensing
This could indicate the water valve on back that sends water to ice maker is not working. The coil can be checked with an ohm meter. I also can help you diagnose the problem. Send the model number of your refrigerator so I can help you better, Thanks, Sea breeze seabreezehvac@yahoo.com
Below you can visit my site and enter model and part numbers in search feature, we offer free help and assistance.
Mar 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
