My kenmore washer just stopped working one day while it was filing up with water. The water stopped and i thought thats odd so i went over and tryed to play with it but none of the functions work
    President:
  • Washing Mach... Master
  • 2,651 Answers
Try applying pressure to the lid assy, did it kick on??? can youhear a "click " when you lift adn drop the lid??? if not then oyou have an isssue with the lid switch, you can bendthe actuator arm ( the left side door hinge", towards the back of machine to hit the lid switch better
Posted on Jan 26, 2009
Kenmore elite washer when i turn it on there is no water going into machine
Check external valves are open After that, the water intake is controlled by electric AC solenoid valves, one for hot and one for cold. You need to see if volts are going to the solenoids. The odds that both solenoids went at the same time are small. I suspect an electric problem
Mar 16, 2014 | GE Profile WPRE6100G Top Load Washer
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
Water will not stop when I shut the washer off.
Possible that the inlet valve has failed and so does not cut off even after the power to the unit or the control unit has been disconnected.
Aug 03, 2012 | Kenmore Washing Machines
Dryer was flooded when we had a sewer back up.
water can damage alot of the parts on the washer and dryer the motor would have been completly under water on both units and the control on the dryer would have gottin wet as a repair man anything can be fixed but to what cost
Jun 02, 2010 | Kenmore 72982 Gas Dryer
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore he2 wont fill with water
first off check your incoming water supply.. also make sure your not using stainless steel hoses manufactured withthe name "flood safe"" big issue with these hoses shutting off premature(they have a built in shut off check valvewithin the hose itself, .. replacethehoses if you have these. if not and you have good incoming water supply, soundslike yo may have a faulty inlet water valve.although usually onyl no hot or no cald the fact you haveno either water temp, thats odd
Mar 04, 2009 | Kenmore HE2 Plus Front Load Washer
My Kenmore washing machine he3
I had the problem of my HE3 washer would not drain all the way. Well I am pretty good at fixing stuff so I took apart the botton panel and there was the drain. I opened up the drain plug with a small bucket (gallon size) underneath and it started to drain and drain. Well about 3 gallons and five big beach towels on the floor i thought I fixed it. I found a service award badge and a couple of small socks. So I put everything back together and started to run a cycle. After the cycle finished my daughter decided to open the door and realized it was full again. After we got out the shop vac and sveral more beach towels. I go back to the drain plug and started to noticed the the drain area is clear. So I thought it was a fluke. Unpluged the washer for a few minutes and started another cycle. Once I realized the washer did not drain again, I was starting to get mad. I took the bottom panel off again and looked under the drum and realized I might new a new pump. Well I called my dad to run the issuse by him to see what he thought. About that time my son opened the washer no realizing I was working on it. I am really mad now. My dad stops by and helps clean up the water. He looks at the drum and realizes the rubber drain piece that comes off the drum twists when it is on the drain mode. So I pull the spring clamp off and put a stainless steel hose clamp (.89 cents) and lined up the black rubber drain piece the way it is suppose to on. It has been working great every since. Sometimes you need about 6 gallons of water to realize that it is always the simplest thing that stump you.
Oct 29, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
