For that optiplex 330 can I just put a new Hard Drive?
  • 2 more comments
  • jay vee Jan 28, 2013
    Beyond my expertise, it might well work
  • jay vee Feb 01, 2013
    I will, still waiting for our order
  • jay vee Feb 12, 2013
    still waiting for new Hard Drive not a top prioty at this pont
  • joecoolvette
    joecoolvette Feb 12, 2013
    OK, thanks for the update.
  • Computers & ... Master
  • 5,660 Answers
Sorry, first time I have seen your query.
http://www.fixya.com/support/t16086233-dell_optiplex_330_starts_one_second
Restarting is bad Electrolytic Capacitors on the motherboard.
Radial Aluminum Electrolytic Capacitors to be more specific.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
May require a bright light for visual inspection.
You're not only looking for the Vent Cover to be bulged up, or popped open, Jay; you are also looking for the Bung to be partially pushed out.
Bung is on the Bottom of the capacitor, so this means if the capacitor is bad, it may be on a hard lean.
What is happening, and why:
Let's start with the basic construction of an Electrolytic Capacitor.
1) Case:
The case is cylindrical in shape, and made of Aluminum. Looks like a miniature Coca-Cola can with the top, and bottom cut out.
The top is sealed with a Vent Cover.
Flat thin disk shaped aluminum 'lid', that has an X or lK etched partway into it.
The bottom is a flat disk also, but composed of synthetic rubber.
This is the BUNG.
2) Internal Components:
There are 3 strip layers inside;
A) One strip is an aluminum metal foil. It is the Conducting Strip.
Has the Positive lead connected to it. (Lead. Think stiff wire)
B) One strip is also made of metal, but has a non-conducting medium applied to it. It is the Non-Conducting Strip.
The Negative lead is attached to it.
Both the Positive and Negative leads poke through the Bung, at the bottom of the capacitor.
C) The last strip is composed of a paper-like material, and is soaked with Electrolytic Paste
The Electrolytic Paste soaked strip is laid in-between the two metal strips, and all three are rolled up tightly.
This is a basic explanation. There are Several of these layers inside an Electrolytic Capacitor.
When an Electrolytic Capacitor starts to go bad, the paste inside (Electrolytic Paste), develops a gas. Hydrogen Gas.
The gas expands inside the case of the capacitor.
When enough pressure has developed, the seals on the capacitot are compromised.
The Vent Cover etched shape breaks open, and/or one side of the Bung pushes out. (This makes the capacitor lean hard to one side)
The Electrolytic Paste begins to ooze out.
So much paste loss, and the capacitor operates in a weakened state.
TOO much paste loss, and the capacitor fails.
A Capacitor is designed to Slowly build up a charge, then release it all at once. This can be seen in some camera flash units, that use capacitors.
Crude explanation, is to imagine a large swimming pool being filled up with a garden hose, then one side of the pool is taken down all at once.
Capacitors are used as Filters, and Voltage Regulators.
The one's used as voltage regulators are in the Motherboard Voltage Regulator Circuit,
Part of what the motherboard voltage regulator circuit does, is to regulate voltage for the Processor.
The Processor (CPU) MUST have a steady, 'clean', supply of Voltage, and it MUST stay within the tight tolerance range for the Processor.
Cannot be too little voltage, or too much.
Processor doesn't receive the correct voltage it turns off. (BIOS turns it off)
Weak capacitor, or capacitors; will regulate the voltage, then break down, and Processor turns off.
Capacitor builds back up again the Processor turns back on.
http://www.youtube.com/watch?v=KN6_-8fYHo0
Starts at 0:04
Solution:
Bad capacitors can be replaced.
Now...........are all bad capacitors going to show visual signs of failure?
Maybe not.
Sometimes the Electrolytic Paste dries up inside, and no visual outward signs of failure are shown.
HOWEVER..........due to the Capacitor Plague, and the fact I have done this repair on SEVERAL motherboards; it is MHO they can be replaced, and a good motherboard again is the result.
http://en.wikipedia.org/wiki/Capacitor_plague
What really transpired, but is no longer talked about;
In a large capacitor company, in a large country; there was espionage.
A gentleman was fired from the company. In retribution a female co-worker decided to steal the companies Electrolytic Paste formula. A HIGHLY guarded secret.
She took the formula to a neighboring country, where they used the formula, and produced 1000's upon 1000's of capacitors.
(Looking back now it must have been millions)
Unknown to her the company had caught wind of what was going on, and before she grabbed the formula, they gave her a bogus formula instead.
The formula did not have the correct ingredients, to keep the Electrolytic Paste from developing gas.
These capacitors are STILL affecting us TODAY!
(From I believe the early 70's)
All electronic units that use Electrolytic Capacitors can be affected, not just personal computers.
This is why I believe there is a high rate, of replacing the bad capacitors, and the motherboard will work again.
A) http://www.hardwaresecrets.com/article/595
B) http://www.youtube.com/watch?v=YCSNWi3UHf4
C) http://www.mouser.com/Search/Refine.aspx?N=12013592
Capacitors used on your motherboard are rated in Microfarads.
Symbol is uF.
Let's use a 470uf capacitor at 16 Volts, for an example,
Under the Capacitance heading, scroll down. Click on 470uF
Under the Voltage heading scroll down, click on 16 V.
Under the Termination style click on -> Radial
Leave all the other fields ALONE.
At the left side there is an -> Apply Filters, and there is one to the far right side also, under the chart.
Click on Apply Filters.
This is what you get,
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw?P=1z0wrk5Z1z0x565Z1z0z7l5
Scroll down a little.
The only thing you are concerned with now, is the size of the capacitor.
Case Diameter, and Case Length.
If it states General Purpose Electrolytic Capacitors, don't sweat it.
They ARE computer grade, I assure you.
Need advice in de-soldering, and soldering? Just post back in a Comment. I'm your man.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 26, 2013
  • 1 more comment
    It doesn't restart like that, it restarts after 25 seconds when it doesn't start normally or any of the other options, I'm saving this when II go into it again when my Hdrives arrive
    One I know is definitely the hard drive, but changing the gpec is beyond my expertise Thank you
  • joecoolvette
    joecoolvette Feb 01, 2013
    Jay Vee, you get that harddrive replaced, how about posting back in a Comment? Regards, joecoolvette
3 Suggested Answers
  • 5 Answers
SOURCE: My dell optiplex 330 can not switch on, I don't know
get a new power plug
Posted on Jun 26, 2009
  • 8404 Answers
SOURCE: How do I add a hard drive to my optiplex 330
Oplen the cover ... physically install the device ... making SURE it is the proper type ... plug it in following the manufacturers instructions.
Posted on May 02, 2010
On boot up I have no video display on my dell optiplex 330
It could be one of two things, either your monitor is bad or the video card is bad. Try taken connecting your monitor to a different computer. If the monitor works then it the video card. You could just purchase a new video card and put in and it should work
Sep 16, 2014 | Dell OptiPlex 330 Desktop Desktop Computer...
Dell Optiplex 330,won't boot memory parity error, tried new bios battery, new ram stick, still won't boot,actually had two at same time the other I ran a advanced diagnostic test said hard driv
I found this
Customer's Optiplex 330 did the same thing today; no beep codes (due to lack of on board speaker). Solid/orange light on front of case indicates board or cpu. I isolated every component not soldered down (RAM, HDD, Optical, etc). Considering all the fans and lights on the MoBo were functioning, and no physical damage to the CPU was apparent, and the BSOD presented the "memory parity error; system halted" (meaning it's memory, graphics memory, or cpu and we've eliminated possibly CPU and RAM) my conclusion is that the problem resides in Graphics memory failure. Considering the error message is very vague and generally insists "motherboard", the gpu in an optiplex 330 is integrated ON the board, lumping it all together.
and general memory parity fail information
memory parity error fix Google Search
Nov 22, 2017 | IBM ThinkCentre Computers & Internet
Ell optiplex 330,won't boot memory parity error, tried new bios battery, new ram stick, still won't boot,actually had two at same time the other I ran a advanced diagnostic test said hard driv
Is it a raid drive? If so you need to format it correctly. If not, check the bios setup and insure your uefi or ahci and legacy options are correct. Check the sata operation should be usb. Check that the boot sequence is in order. Give me more information and I'll help you
Oct 30, 2017 | IBM ThinkCentre Computers & Internet
My dell optiplex 330 fails to start. dignostic light 3, 4 blinks all the time the processor run and the hard drive is also fine please help solve problem
There is an issue with a fulty RAM module. Open up the case and remove one of the RAM modules. try restarting. If that doesn't work, put the one that you took out back in, and remove the other one. If that works, then you need to buy a new module to replace the one that was bad
Mar 04, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Hi there! please show me or tell me what to do with my Dell Optiplex 330, When i switch it on the fan runs and it displays but it does not go beyond the DEll POST screen. thanx timothy
It sounds to me as the expensive part is OK.
First try and boot from your System CD. If that works then your system software is corrupt and a repair is required. To do that, load the rescue/system disk and follow the "Repair your system" prompt. That will fix your problem, if that option is not available and the computer boots OK from the CD then re format your hard drive and then you can put a fresh install system on it restoring your data from your back up discs.
Hope that helps.
Oct 25, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
When i start my dell optiplex 330 pc, the power light will be blinking orange and all the fans on the pc do not work but the orange led on the motherboard works.
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 16, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
May 02, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Have two computers and have put both hard drives in the same towe
Let me get this straight, because the title got cut off:
You pulled a hard drive from one computer and put it into the other, and it is not being recognized.
Did you check the jumper settings on the drive? From the factory it was probably set to master. Reset the jumper to CS (cable select)
and try again.
Apr 18, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Computers & Internet Logo
David Payne
David Payne
