Need manual for warm morning natural gas heater model #VR65
MANUAL
  • 1019 Answers
SOURCE: glo warm heater
I,d suggest that you have either a case seal Damaged, allowing air into the casing.
Also possible fault may lie within the Flue air pressure Valve/Switch If applicable.
The heater/Boiler will have certain conditions to meet.
The Fan/flue switch ( Pressure switch. Will be designed to speed up the fan, before firing the main Burner.
As for the Noises, i,d suggest that the boiler is whats commonly known or reffered to As Kettling. Which usually indicates Overheating. This would cause the main-burner to distinguish as a fail safe.
Recommendations:- De-scale the heater, with a commercial descaler. Thoroughly flush the System. Then re-fill with required Amount Of Commisioning Fluid. i.e Fernox Or Sentinel et,c.
Also get the Fan/flue checked out for correct running speeds.
Mike @ compurepair.
Posted on Mar 16, 2008
  • 108 Answers
SOURCE: Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Posted on Dec 09, 2008
  • 333 Answers
SOURCE: Need Manual for Reddy Heater Model M30
Click on this link to see if this is your heater http://12.153.20.74/manuals/113893-01D.PDF . If this is not click on this link and put in your info. I hope this helps you. http://www.desatech.com/manuals.cgi?products=Construction%20Heaters Don't forget to rate my answer.
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: rinnai natural gas log fire heater
12 is a fault code, look in the book if you have if, i think 12 is no or low gas pressure, cheers
Posted on Feb 05, 2009
SOURCE: Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Posted on Feb 24, 2009
Manual for honeywell natural gas valve. Vr8204c 1084
Google for "Vr8204c 1084 manual" ... 1st item says:
http://www.warming-trends.com/manuals/HoneywellTroubleshootingGuide.pdf
68-0047 - VR8204; VR4204 Intermittent Pilot Dual Automatic Valve Combination Gas Controls
Pretty much chapter and verse - you don't usually get any more.XV66OI
This is an industrial valve. Are you safe to meddle with it?
Dec 29, 2016 | Honeywell Water Heaters
Rinnai natural Gas Heater 25 TR (Avenger RCE 670)
this is all I could find it looks like an earlier model, but it may be helpful. sorry it is such a long link. it's the download link for the manual, hope it helps.
http://www.google.com/url?sa=t&rct=j&q=rinnai+natural+gas+heater+manual+avenger+RCE+670&source=web&cd=3&ved=0CC4QFjAC&url=http%3A%2F%2Fwww.finesgas.com%2Fproduct_extra_files%2FRinnai-RCE-592.pdf&ei=rzZgUMbfKpLI9QTwx4DwCQ&usg=AFQjCNGPoBENsIVWy_-1GG94mowsXBSosg&cad=rja
Sep 24, 2012 | Rinnai Heating & Cooling
HL1 error water not heating
check gas pressure if ok check manual bypass see if spring is ok if broken or stuck closed that if ok see if unit is turning off check gas pressure to see if running out of gas and turning off then gas line filling up and turning on again
May 21, 2012 | Raypak 266A Digital ASME Natural Gas IID...
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
Rheem pronto tankless water heater just barely warm model # 74pvn-1. This is in a house we are just purchasing. Also it looks like it may be attatched to another tank water heater , Help please
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sometimes people attach tankless to tank-type heater to preheat incoming cold water.
Additional tanks are also used to store solar heat, and some installations have tank-type because tankless is unreliable. Service technician can sort out the function correctly.
http://waterheatertimer.org/Tempering-tank.html
Owner should read tankless manual thoroughly, especially troubleshoot and maintenance sections. Tankless require yearly maintenance.
Since tankless are expensive to repair and replace, you might be able to fire up the tank-type water heater and provide hot water without much cost.
You can also install tank-type gas water heater yourself. Lowes sells 40 gallon for $317.00, and then you offer 10% less.
http://waterheatertimer/How-to-install-gas-water-heater.html
Apr 19, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have a RTA patio heater and on the box says it will work with LP or Propane but in the manual doesnt go into how to hook it or what needs to be done to LP connection can this be hooked into a home supply...
You didn't specify which model you have (Table Top or Tall Patio Heater). In any event, it doesn't matter, as LP and Propane are one in the same. However, it can not be converted to Natural Gas. Rita makes a separate Natural Gas model for that type of hookup.
Feb 10, 2011 | Rta International Patio Heater
How do I adjust the temp on a Williams wall heater model # 1043622?
Found this link to a manual for the Williams Wall Heaters...
Model 1043621.05 is LP Gas Model Model 1043622.05 is Natural Gas Model
http://www.hammerwall.com/Download_Manual/3249/
Temperature is set using a thermostat as explained in the above manual.
Use IE Explorer Browser, manual does not display in Google Chrome as a number of other PDF files don't either, must be a bug.
Nov 12, 2010 | Williams Heating & Cooling
Heating & Cooling Logo
586 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
