Question about Precor Polar 43579-108 Heart Rate Monitor For Fitness Equipment
I have a Precor 9.25 tread mill with a heart rate monitor that you strap to your chest. I cant find what batery to put in the chest strap can you help?
Looks like it should be 3/4 in diameter thickness ? voltage ?
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: How do I enable my EFX 544 to give my heart rate
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
Posted on May 17, 2010
ercupa190
  • 12223 Answers
SOURCE: how do you replace bearing on a precor 9,25 need to replace bearings on precor 9.25
see the videos: God bless you
Posted on Sep 23, 2012
The heart rate monitor chest strap no longer works and I need to buy a replacement. Which are compatible ?
Maybe you can find a replacemente. Do a google search for terms
Heart rate Monitor, the make, model and PARTS
If can't find, do a search for Manufacturer's website and try to get information from some "Contact Us" option. Some even have a phone number.
A shot in the dark:
Accessories Polar USA
Polar Transmitters Straps and Heart Bras
heart rate monitor parts Google Search
Elastic Strap for Heart Rate Monitor Garmin
Sep 01, 2015 | Exercise & Fitness
Tip
Tips For Your Heart Rate Monitor
First, you want to adjust the fit of the chest strap. <br /> <br /> Moistening give a more comfortable fit by reducing friction and will also help create a better connection between your skin and the receiver. It can also increase the lifespan of your belt.<br /> <br /> When properly looked after, your heart rate monitor watch should far outlive the chest strap. More often than not any problems you find with the watch can be traced to the chest strap or the batteryIn terms of conservation, the most important thing you can do is ensure that your watch is no longer monitoring after you return from your run. <br /> <br /> This should be easily achievable through the interface on the watch. Separating the watch from the monitor component by a significant distance will ensure that no unwanted connections continue after use.<br /> <br /> Where possible, make sure to remove the electrical component before rinsing the strap with some running tap water. If the watch and electrical component are particularly dirty, you can use a damp cloth to wipe them down, before putting everything aside to dry. Be sure not to leave the chest strap in the sun as this can cause the material to deform, making it itchy and uncomfortable to wear.
on Jan 08, 2011 | Exercise & Fitness
Sportline cardio 660
Try to humidify contact area on chest strap(each side front). Also batterie weak in strap?
May 11, 2013 | Exercise & Fitness
Replace batttery in omron heart rate monitor chest strap
Check out this manual of the Omron heart Rate Monitor. It will help you in solving your problem.
http://www.omronhealthcare.com/wp-content/uploads/HR-100CN_A_M10_120221_web.pdf
Aug 06, 2012 | Omron HR100C Heart Rate Monitor
I bought an ft4 monitor in nov 2010 and when I am exersizing for approximately 20 minutes the monitor loses signal from the transmitter. I can sometimes get a signal back by pressing the transmitter strap...
Look in my tips and tricks page for the most common issues regarding Heart Rate transmission, if none of these fix it, then you "may" have an issue with the equipment itself. Generally the most common issues area:
Strap not on correctly (too loose, too low, upside down, not enough wetness to conduct)
Environmental factors (signal interference, etc)
Mar 25, 2011 | Polar Heart Rate Monitors
How do I enable my EFX 544 to give my heart rate while wearing my polar heart rate chest strap?
May 17, 2010 | Precor C956i Treadmills with HR /...
Watch won't read heart rate
It could be the battery on the strap is not good. However just to be sure make sure you are wetting the strap and it is around chest, front should sit right about on the bottom of pectoral or chest, if you are female make sure it is under your sports bra the bra band will be over it. I would start warming up then hit the start button it should work.
Feb 06, 2009 | Polar M61 Heart Rate Monitor Watch HRM M61
Timex M515 Heartb Rate Monitor in correct readings
I´m experienced the same problem of incorrect readings after a long time without use. I cleaned the rubber parts of the chest strap with soap and water, than I use some silicone grease or other silicon liquid to keep the rubber hydrated. Make a careful cleaning in the contact area between the rubber and the plastic parts, the fissure in these area use to be full of "sweat dust".
Jan 03, 2009 | Timex Digital 30 Lap Heart Rate Monitor...
Polar F11 not responding
I' advise to start with battery check. If the battery is ok, then you will need a professional to find the cause of malfunction.
Dec 19, 2008 | Polar F11 Heart Rate Monitor
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
Precor Polar 43579-108 Heart Rate Monitor For Fitness Equipment Logo
21 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
