Ouellet wall heater isn't working. clicks with thermostat but no heat
SOURCE: 2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Posted on Oct 31, 2008
  • 18 Answers
SOURCE: thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Posted on Aug 04, 2009
  • 288 Answers
SOURCE: Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Posted on Jan 09, 2010
  • 1015 Answers
SOURCE: williams 5009622 dual wall heater
It sounds like the gas valve has some debris in it that is causing internal relay from opening without some help. I would check and clean electrical connections on gas valve and make sure you are getting at least 24 volts to gas valve when thermostat iscalling for heat. I would also actuate gas valve several times in a row to see if it frees up any. If that doesn't help you probably need to replace gas valve. I think you will need a new valve but it's worth a try. Good luck. Thank you.
Posted on Dec 26, 2010
  • 224 Answers
SOURCE: power at the wall thermostat,
It could be, here is what I do to verify that the problem is in the thermostat. Remove the thermostat from it's mounting plate, you should now be able to see the wiring for the thermostat. Locate the red and white wires, they usually run the control for the heat, now place a jumper to join the red and white wires. The heater will now run with out a thermostat, if it runs yes it is the thermostat, if not you need to look in to the control side of things. This means either good electrical trouble shooting skills or time for the repair man.Good luck
Posted on Jan 03, 2011
Thermostat clicks on then off quickly repeatedly when heating but does Not turn on heat. Until I manually turn thermostat to Off on Heat/AC and manually turn Fan Switch to Manual On for 10 seconds. Then...
Hi Daniel
My name is John
Remove the thermostat from the wall. Jump the R & W and see if the heater countinues to run if it does then you have a bad thermostat
Mar 13, 2015 | Heating & Cooling
I have an 05 Chevy impala that blows out cold air and the hot coolant temp light comes on which causes my car to decrease in speed. The car isn't over heating, there are no leaks, but antifreeze keeps...
Possible heater core poss. thermostat ck. both heater hoses at fire wall 1 hot 1 cold its the core ck pass side floor wet its the core Maybe head gasket
Nov 08, 2012 | Cars & Trucks
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
Need repair manual for eden pure heaters
The Edenpure Gen4 and US-1000 have a set of 3 - 500 watt bulbs that generate the heat. You'll likely need to buy a new set of bulbs every heating season ($60) or pay an Edenpure service center $100-140 to replace them for you. (Almost imossible to get SCI to cover the the bulbs under their so-called warranty)
Unfortunately, despite the hype printed on the box and Suarez Corporation Industries advertising, those bulbs last less than 500 hours of operation in those heaters. Suarez Manufacturing Industries/Pinnacle Systems have no engineering staff nor did they perform any durability testing on the heaters or any heater components.
Thus you, as the consumer, are stuck with continually the bulbs (in the US-1000 and Gen4 at least).
Apr 01, 2012 | Heating & Cooling
My heater is not getting hot
Hello! There are only a few reasons for this awful event to occur in early December...Either Hot water isn't circulating through the heater core, the thermostat isn't opening or the door that directs heat is faulty...Is the temperature gauge showing normal? Next, is the upper radiator hose hot and hard? If the last two answers are yes then hot water is circulating...The unit that controls the doors ...ie...heat or defrost is called an Actuator...Also the lever that opens the heater may be at fault....LETS ELIMINATE...
Is there defroster heat? If no the heater core isn't opening ..If yes then the actuator is the culprit...You can check the heater by feeling of each of the two hoses that come through the firewall into the inside...If they are both hot then the heater core is open and functioning...If one is cold the heater isn't being opened by the temperature control..Or it is simply blocked with gunk....It's a 99 and getting old...I would suspect that IF the upper radiator hose is hot and hard and the temperature gauge is normal all is well with with most components and the next step is; Are both heater hoses hot...Your going to have to narrow this down for me to pinpoint the cause...See diagram below of the door actuator allowing defrost heat to be sent to the heater floor duct...
Send a comment with results and or observations...Remember"your my eyes and my hands"...Guru ...Saailer
Dec 02, 2011 | 1999 Dodge Durango
Heater stoped blowing out hot air
Your problem can be caused by a bad thermostat, bad heater control valve, a heater door that's not opening or a clogged heater core. If the thermostat is good, check your heater hoses when the heat is on. Both should be hot; if one isn't there is a vacuum operated device inline with one of the hoses (heater control valve) make sure the vacuum line is connected to it. Sometimes you can manually force the valve to move; if you can do it and see if the 2 hoses get hot as a result. If they do, change the valve. The heater door is inside the vehicle and it too is usually vacuum controlled and often somewhat involved to service. I'm not sure of the exact configuration of your heater core but they too can become very involved to replace. More than likely the heater core isn't clogged and there's a very good chance you just have a sticking heater control valve.
Jun 23, 2011 | 2003 Chevrolet Impala
I have 2 Honeywell TH5220D thermostats installed in my house & want to replace 1 with Honeywell TH6220D 1028. The wiring on the existing thermostats is as follows (a jumper wire from Y2 to W2,1 wire...
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Apr 06, 2010 | Honeywell Electronic Programmable...
Thermostat not firing central heating
Dec 08, 2008 | Dayton Electric Heater
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
