Question about Maytag 24 in. PDB1420 Built-in Dishwasher
Food particles are on dishes after washing
I have a Maytag Performa PDB1420AWX. It is leaving small food particles on the dishes after finished washing. I rinse and scrape the food particles off before putting in the dishwasher.
Why is it doing this?
    Problem Solver:
  • 9 Answers
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Posted on Jan 26, 2009
  • 59 Answers
I had the same problem where food seem to be still on dishes after complete cycle. Long story short, I found out that the dirty water was not completely draining after each cycle. I have had a backup in my kitchen sink for awhile where the dishwasher drain hose is attached under the sink. What happened is since my kitchen sink has had a slow drain due to stoppage, the dirty water from the dishwasher ejecting into the sink drain has been backing up. Thus due to the sink being higher than the pump on the dishwasher, the pump could not overcome the buildup and dirty water has been going back into the dishwasher and not completely draining. Then you have wash cycles where dirty and clean water are circulating and your dishes never get clean and you see debris. This may not apply to a lot of folks, but will save you from blaming the dishwasher. Just get your drain cleaned so the dishwasher water can eject freely down where the drain cycle completely drains the filthy water out.
Posted on Feb 02, 2015
Poor rinse on maytag model mdb8600awq
Did you check the screen at the bottom of your dishwasher? It may be clogged with food particles. If these particles aren't small enough to get flushed down they will just recycle through the water.
I always make it a practice to rinse off my dishes before I place them in the DW. Some newer models have better drainage systems, but perhaps yours is an older model.
Dec 22, 2012 | Maytag Dishwashers
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Food particles remaining on dishes after cycle is complete.
Hi
While putting dishes in the washer and obstructing the spray ams which causes food particles to stay on dishes. After loading dishwasher and pushing in baskets ,be sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
However the other causes for this problem are…
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 14, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
Most likely causes are:
Hope this help. Good luck.
Sep 11, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Food particles and what looks like sand consistently left on dishes after cycle is finished
Clean the filter.  It is at the bottom below the wash arm.  Remove the wash arm by lifting it off.  The filter is a round ring the can be lifter out and cleaned.
May 20, 2009 | Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Dishwashers Logo
972 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
