Question about Frigidaire Electric Dryer
Procedure to reset circuit board for aeq8700feo
  • Official Brand Answer
  • 4,342 Answers
Hi Robert Mujica - Usually this type of information is not release to someone who is not a technician and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install/remove for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area may guide you through this process.
Posted on Jan 23, 2013
I have a Vizio E322AR tv, and the screen goes black after a few hours. The reset procedure brings it back to life for a while. Any suggestions on what may need replacing?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 05, 2016 | Vizio Televison & Video
Wondering how to diagnosis a 55 in samsung led tv with solid blue screen. It has sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. The fault is related with the video processing section circuit at the main digital board. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 22, 2016 | Samsung Televison & Video
I have the 60LN5400-UA I spoke with someone the other day and they suggested to order a power board. I am confused I have no red stand by light but I can see the lights through the back panel.
If the power indicator LED at its front panel is ON, then the power supply regulator section circuit board is OK. The fault should be with its digital main board itself. After power is switched ON, the poser regulator board supplies different voltages to different stage circuits inside. These voltages are controlled by the main system control IC, at its main digital board. Now it do not work, and why you can't power ON the set, either by remote control, or with the front panel control.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 01, 2016 | Televison & Video
I have a Vizio E430VL main board where all the inputs went out. Is there a simple fix to revive the main board? Ideal with circuit boards on a daily basis so working on board level is not an issue.
Jun 05, 2016 | Vizio E420VL 42 in. HD-Ready LCD TV
Have a sharp aquos Lc-40e67un tv tried the reset procedure no fix. Called tech support was told convergence problem. Is their a part fix for this
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ...
Jun 03, 2016 | Sharp Televison & Video
Resetting the board in dishwasher
If there is a procedure to reset your board it would be to remove power, then restore power to the dishwasher and press certain combination of buttons within certain number of seconds. As far as I remember that procedure was available and was described in tech documentation for Whirlpool, Kitchen Aid and Kenmore dishwashers. I don't recall such procedure for Maytags.
The tech documents are usually under the kick panel, which is under the dishwasher door.
The "hard" reset procedure for any control board would be the following sequence (standard electrical safety and common sense rules apply):
  • remove power (unplug, turn off circuit breaker, etc.)
  • access the control board; with Maytag dishwashers it would be inside the door
  • make a picture or descriptive list of all plugs and wires connected to the board so you could reconnect those later
  • make sure you don't have an electrical charge on yourself - touch the grounded part of the dishwasher, usually the frame
  • CAREFULLY (you can damage your board) disconnect all plugs and wires from the board
  • with a large flat blade screwdriver or any other metal tool insulated from your hand, briefly short the connectors on the board. If you can identify where the power wires connect to the board - short those between each other first.
  • put all plugs back using the picture or the description you've made before disconnecting; put the appliance back together. turn on the power.
Good luck,
Vlad with First Choice Appliance, Sacramento, CA
Jun 30, 2012 | Maytag Dishwashers
Resetting the dishwasher
If there is a procedure to reset your board it would be to remove power, then restore power to the dishwasher and press certain combination of buttons within certain number of seconds. As far as I remember that procedure was available and was described in tech documentation for Whirlpool, Kitchen Aid and Kenmore dishwashers. I don't recall such procedure for LG.
Good luck,
Jun 30, 2012 | LG Dishwashers
Having fitted a new battery I need to re-set a Crane & Viceroy atomic watch but cannot find the re-set button.
The reset is typically not a button. If you look at the back lid with the watch open you might have instructions to reset or "AC" the watch. Usually this involves using tweezers or lever to contact the battery and circuit board to clear it. My suggestion for this procedure is to see a watch maker/technician since the circuit board is easily damaged.
Sep 15, 2009 | Watches
Error E42
Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Or try:----------------
TRY THIS STEPS... Reset Counter Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Aug 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
C 41
Try replacing the thermal fuse in the fuser. Then reset your C41 by using the "08" mode, code 89, reset to 0. If that doesn't work, replace the thermistor and do the same procedure again.
Jun 12, 2006 | Toshiba 2060 Copier
Frigidaire  Electric Dryer Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
