Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana bottom freezer/ refrigerator
My Amana BX22S5E bottom freezer/ upper refrig is freezing in the freezer section but slightly cold in the upper refrigerator section. I can see heavy frost on the back wall of the freezer and it sounds like the fan that pulls cold air up to the refrig section is working. What & how can I troubleshoot to determine the cause?
  • 1 more comment
  • Ron Francis Jul 16, 2007
    The evaporator fan is definetly working, the coils were all iced up and the thermistat looks like the one in your picture with a separation of the plastic cover at the top. I metered the thermistat with an ohm meter and got 50 ohms across the wires and then metered the heater and got 20 ohms thru the element. Does this sound like good or bad ohm readings? Iam going to replace the thermistat first, just wondering about the heater element.
    Thanks
    Oldgeezer
  • Anonymous Mar 16, 2014
    freezer on bottom of refrigerator iced up in the back, and not cold in upper refrigerator
  • Anonymous Mar 17, 2014
    amana ar266zbw top of coil behind freezer panel freezes up but not bottom of coil
    President:
  • 878 Answers
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
  • Ron Marek
    Ron Marek Jul 16, 2007
    Geezer, the heating element is ok, just change out the bimetal..Catriver
SOURCE:
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
Freezer is working but fridge is cool not cold
the damper door vent is not opening fully if at all between the refrige and freezer compartments,it can freeze up from condensation or if controlled by a motor the motor can be bad its behind a plastic grille
May 24, 2010 | Amana ABB1921DE Bottom Freezer...
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
1,064 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
