Question about HP Compaq nx6110 PC Laptop
Usb poblem usb pendrive not support
  • HP Master
  • 27,725 Answers
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply Hope this helps.
Posted on Jan 19, 2013
My toshiba 8 gb pendrive is not recognised by desktop,
does this pendrive work on other computers if it does then use a different usb port if it wont replace pendrive
Aug 01, 2014 | Microtoolz PenDrive Autorun
Cannot copy any file like movie in pendrive. everytime when copying any movie in pendrive it will disconnect automatocally,and after sometime automatically reconnect. what do i do???
hello
try to check your usb port, try another pen drive, maybe the pendrive is faulty, if not the pen drive is faulty, check your usb port. maybe your pendrive is 3.0 and your usb port is 2.0 only.
thanks
Feb 27, 2011 | Intel DG31PR Motherboard
Hello sir i have kingston 32gb Ccore ccm3110 pendrive it can copy any thing but after copying to my pc the first video file can play ony 14.2 min and others will not open at all solve my problem please
May be your pendrive has corrupted the files or may be your pendrive has some viruses.
I suggest u not to use so much memory on pendrives as sometime pendrive automatically corrupt your data.Use small memory of pendrive.If u want to use big memory it's better u use hard drives
Jan 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have 8gb kingston pendrive..and i set my pendrive drive name to 'myname'.i already used my pendrive 7.4gb.and got a lots important files..when i plug in the pendrive,it will automatic install driver...
yes your pendrive is attactked by a severe virus.......you need format it you can do only one thing click on format option or restart the pc then press f8 thenan stat windows setup when you reach the formatting option then only format that pendrive.............
Nov 27, 2010 | Computers & Internet
HOW TO USE PENDRIVE AS RAM IN WINDOWSXP
You cannot use a pendrive as RAM in a computer or laptop, but you can use the pendrive as an external USB storage drive/device.
Jun 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb problem
There is no repair options for transcend pendrives.You can try formatting them, by right clicking on the device driver and selecting format option.Press start and the pendrive is formatted.Also the data in the pendrive will be deleted.Generally if the device is not being detected, then the pendrive can be claimed for a lifetime warranty.
Jan 19, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Kingston Pendrive 1 Gb
pls confiure usb port for ur pc. the problem is with usb port and not pendrive
Jun 09, 2008 | Electronics - Others
Pendrive related problem
u need to check the working of pendrive on some other system/pc. may be ur pc needs usb configuraton?
Apr 13, 2008 | Electronics - Others
Pendrive usb port
have the correct drivers loaded into your pc and try to jump form one usb port to another in order for your pc to recognise the pendrive.
Apr 09, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
HP Compaq nx6110 PC Laptop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
