Question about Zoom X6 (5590) DSL Modem (55900003)
My zoom x6 modem doesn't block pings (ICMP). How do I configure?
When I try using "shields up" to test my firewall, it fails the ping test, responding. I cannot find any way to configure it to prevent this.
Blocking ICMP pings on a Zoom requires a few steps:
1) Go to Advanced Setup and select Advanced Firewall Filter.
2) Enable Advanced Firewall Filter.
3) Click on Security Policy Configuration.
4) Click on Policy Rules for "Add Firewall External-Internal Filter Rules."
5) Click on Add Policy Rule.
6) In the row labeled "Protocol," select "neq" and enter ICMP where it says "(Protocol Number or Name)."
7) In the row labeled "Select the direction to filter packets," select BOTH.
8) In the row labeled "Filter Action," select DENY.
9) Click on Save Changes and repeat 1) through 5).
10) In the row labeled "Protocol," select "eq" and "TCP." Below, select BOTH for direction, and ALLOW for filter action.
11) Save changes and repeat 1) through 5).
12) In the row labeled "Protocol," select "eq" and "UDP." Below, select BOTH for direction, and ALLOW for filter action.
13) Save changes.
14) Go back to Basic Setup and save changes to Flash.
That's it. Good luck!
Posted on Sep 21, 2010
I have a Zhone ADSL2+ CPE Router, Firmware version: 01.01.26. I did some test and I found the following problem. For this test, usually we did a ICMP test (ping test) to local , national and...
Try tracert command to web site, that doesn't open. If trace is ok - than it can be yours web browser configuration, or pc firewall, or parental control. Try to open web sites with fresh install of another browser, disable windows firewall, any other firewalls/av and any parental control.
May 21, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
I purchase a netgear universal wireless internet adapter to connect on my samsung tv to get the internet , netflik etc.....i was not able to pass the test with the gateway ping which failed. the model...
I have a couple of questions
1. What gateway are you pinging?
2. From what device are you sending the ping?
If you are trying to ping the gateway on the modem/router provided by your internet service provider then you will not get a ping response, this is because it's configured not to respond.
Oct 06, 2017 | Computers & Internet
For some reason I am unable to get onto facebook however anyother websites are fine....like my computer is blocking facebook?
ping the face book site
that is go to the DOS prompt and type ping www.face book.com this will give give 4 replies back if the site is responding. If not then you have a firewall issue or a DNS (Domain Name service) issue.
Ping this ip 66.220.153.15 if you get the site with this then there is a problem with the DNS.
Apr 29, 2010 | Computers & Internet
DNS Server is not responding
On your computer, Click on Start and then RUN and type CMD... on the black screen/DOS prompt type there FlushDNS and press enter, this will clear out the DNS and should work
Mar 28, 2010 | D-Link DIR-300 Wireless Router
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) multiplex..llc virtual...
ftp://ftp.zyxel.com/
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Apr 02, 2009 | Zyxel Prestige 660HW Wireless Router...
UNABLE TO BROWSE INTERNET
type in run "ping yahoo.com -t"
if u get reply then your internet is ok then u have some firewall issue off your windows and antivirus firewall.
Mar 16, 2009 | Microsoft Internet Explorer 7
CIsco ASA 5510 fire wall problem
Hi Thangaraj_j,
Can you provide the topology of your setup? Can you provide also the following:
- running configuration of the ASA
- ip address of the server (what kind of server is this? what tcp/udp port does it use)
- show xlate
- show con
- show log
Just a quick try, have you tried clearing the translation and the arp table?
commands to do it:
clear xlate
clear arp
clear local
Let me know and if it still doesn't work, try to ping the server from the pc clients and see if ping does work. (you need to allow icmp to pass thru in case you are denying it for testing purposes) Just send me the additional information given above.
Regards,
ex_ocsic_cat
Nov 01, 2008 | Cisco ASA 5510 Anti-X Edition...
Help with installing a sonicwall soho tzw no software.
Hello dlewis2900, What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
Sep 03, 2007 | SonicWALL TELE2 Firewall
Sonicwall tele2
Hello ask4jon, I gave this advice at an earlier time and I think it applies here to. What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
May 29, 2007 | SonicWALL TELE2 Firewall
Zoom X6 (5590) DSL Modem (55900003) Logo
526 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
