Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
How to take out blower motor on 1995 Chevy 1500 silverado 4x4
Blower motor for heater stops working on high and makes noise
    Scholar:
  • 117 Answers
Sounds like two problems. No high speed could be the blower relay located by the blower motor. The blower motor is located under the dash on the passenger side of truck. You may need to take off the sound kick panel to see the motor. It is connected with 4 screws to the housing. Take out the screws and it should come out.
Posted on Nov 02, 2013
3 Suggested Answers
SOURCE: need wiring diagram for 1995 chevy 1500 silverado 305.
need a wiring schematic for a 90 s-10 blazer cut the wires to dist now cant find leads
Posted on Aug 24, 2009
  • 79 Answers
SOURCE: 1995 chevy 1500 pickup 4x4 4L60E trans
the computer is different on the 4l80e put the wiring should be the same. the case has the same bolt pattern. The bolt pattern stayed the from on the pickups from atleast 2001 down. You can use an LS series style motor's transmission if you wanted. You will just have one less bolt in the transmission case to the block.
Posted on Jan 10, 2010
4x4 tied to blower motor???????
Check your fuse box for a bad connection or loose fuse. if all fuses are tightly in fuse box I would suspect a wire on back side of fuse box having a loose connection if this was helpful please leave me a good review
May 25, 2013 | 1995 Chevrolet Silverado 2500
Install a 1995 blower motor on Silverado 4x4 truck
Sounds like your blower motor resister is bad,when going bad,it may not work or not work on all speeds,the motor will work or not,don't think it's motor.Resistor is located next to blower motor,2 screws hold it on,here's what it look's like and where blower motor is.Enlarge picture to see where resistor is.
Jan 19, 2013 | 1995 Chevrolet K1500
My heater blower does not work on low in my 1998 chevy silverado 1500
If it is only working on high the blower motor resistance has to be rplaced it controls the speeds of the blower motor.
Feb 09, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I own a 2001 Chevy Silverado. The fan motor is making weird noises and only works on high. How do I change out the fan motor in the dash and where is the resistor that has probably blown out due to the...
The blower motor is on the right side of the dash.remove the lower right kick panel,the motor bolts in with three screws.the resistor is located to the left of the blower.check your connector on the resistor as these like to melt.you will need to install a new pigtail if this has happened.
Dec 02, 2010 | 2001 Chevrolet Silverado 1500
The heater fan on my 98 chevy silverado stopped working... worked on high at first but made a high pitched noise and stopped all together
Run 12V directly to the motor and see if it will run, if it dosent than the motor is bad, if it does than the resister is bad, the resister makes the blower run and also regulates the speeds for the blower, but chanses are if it was making a high pitch squeel before it quit the motor went out.
Dec 10, 2009 | 1999 Chevrolet Silverado 1500
Tapping noise near computer 1994 Chevy 1500 Silverado
air recir actuator motor shorted you can reach between blower motor and heater case and unplug a pain to replace
Oct 29, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Blower motor or resistor?
I had a truck about the same year with the same problem, it was the wiring harness, but id check the resistor and the fan first before replacing anythings,
May 20, 2009 | 2002 Chevrolet Silverado 1500
Heater only work on high
Most likely is the resistor when they fault the default to high giving you off and high only
Dec 03, 2008 | 2003 Chevrolet Silverado 1500
Problem with fan on a 1998 chevy silverado ext cab 4x4
when it doesnt come on next time, put it on high and give it a hit with your hand and see if it comes on. or test it for power at blower with test lite
Nov 16, 2008 | 1999 Chevrolet Silverado 1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
107 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
