Question about Kenmore HE2 Plus Front Load Washer
My machine won't drain
F=21 appears then Sd or 5d checked the drain even poured water down and it is ok Is there something I 'm missing
  • 5,911 Answers
Click on the following link and follow the steps provided:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Pouring water down the drain probably isn't enough to rule out the possibility of a clogged drain pump. You will need to open the bottom panel of the washer and remove the drain pump reservoir to be sure.
If you require additional assistance, please let me know before rating the solution. I hope you find this information helpful.
Posted on Feb 02, 2009
Error code 5d or f-21
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 16, 2012 | Whirlpool Duet GHW9150P Front Load Washer
We are getting a 5d code and cannot pause the washer to unlock the door and the machine is stuck in this mode. What do we do?
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I have 5d code on my washer
Hi
Daniel
Aug 27, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a maytag HE2 PLUS front load and for the first time i have a 5d or Sd error code, can u tell me what it means???
Hi
Daniel
Aug 27, 2011 | Washing Machines
The washer stops before rinseing and sends a code 5D.
Hi
Daniel
Aug 23, 2011 | Kenmore HE2 Plus Front Load Washer
The machine start to work ,but then i can see 5d and i don't know what it means
Hi
Daniel
Aug 10, 2011 | Kenmore Washing Machines
5d error code
Hi
Daniel
Aug 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi i have a Whirlpool sport duet and after a few minutes it stops going and Sd or 5d comes out on the small screen. What does this mean? Does not say in the owners manuel
Hi
Daniel
Aug 04, 2011 | Washing Machines
Error code 5d -- what does this mean?
Hi
Error code SD or 5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore HE2 Plus Front Load Washer
Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Mar 29, 2010 | Dishwashers
Kenmore HE2 Plus Front Load Washer Logo
150 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
