Question about Milwaukee Tool Home Fencing
Drill bit stuck in impact drill
The bit seems a s if it is jammed
  • 9 Answers
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Posted on Dec 04, 2008
SOURCE: Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
Posted on Apr 11, 2009
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
meleemore
  • 19 Answers
SOURCE: sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
Posted on May 05, 2009
  • 18 Answers
SOURCE: chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Posted on Jul 09, 2009
Drill bit stuck in ryobi impact drill
Put the bit in a vise and try to turn the drill to release the bit. You will need to put a wrench on the area of the drill that's holding the bit and do the turning by the wrench.
Jan 12, 2015 | Ryobi Drills
I have a Hitachi WH 18 DFL cordless impact driver, which I love. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit do
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Jan 19, 2012 | Dewalt 18 Volt Compact Drill Kit
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have a 18 volt makita cordless impact driver i can not get the driver bit out it seems to be stuck in the chuck very tight
Try holding the bit with pliers and running in reverse, maybe with a shot of oil. That might free it up. You can also try tapping it (firmly) on the side of the bit
Aug 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Bit stuck in drill
OK, try to grab the chuck tightener and loosen by pressing lightly on the drill throttle button in whichever direction it takes to undo the stuck in drill bit.
I do this all the time.
Jul 13, 2010 | Ryobi 18v Variable Speed Impact Driver...
Someone stuck a conventional driver bit into the impact driver and it is stuck tight.
VERY GENTLY. . . . use a flat tip screw driver to try to push the collar forward so that it will release the bit. You may need to gently hold the handle of the impacter in a table vice or something like that to steady the tool, then push forward on the collar with a screwdriver and use a pair of pliers to pull outward on the bit at the same time.
Or instead of a screwdriver try vicegrips that are adjusted loose enough to just lock but not squeeze when closed. Pliers that grip too tightly may bend the collar and keep it from being able to slide forward to release bits.
Dec 03, 2009 | Ryobi 18v Variable Speed Impact Driver...
Apr 10, 2009 | Ryobi 18v Variable Speed Impact Driver...
Jan 17, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
Makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Jan 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Home Fencing Logo
69 people viewed this question
Top Milwaukee Tool Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Milwaukee Tool Home Fencing Expert? Answer questions, earn points and help others
