Question about Vacuums
I have vax 1800 pet vacuum. It is picking up fine but very noisy. I have replaced the belt in the past and the noise started then. On looking at it closely today I noticed brushbar was getting worn where it slots in at the side so I suspect it wasn't fitted in properly after replacing the belt. Now in properly but still making terrible noise. There is a bit of a rubbing noise when brushbar moved round. Do you think the brushbar needs replaced? How do I lubricate the bearings to try that before replacing the brushbar completely? Thanks
  • Vacuums Master
  • 18,394 Answers
Spray the end of the brush-bar were the bearings are with WD-40 if that solves the problem replace the bearing when it starts screeching..
Posted on Jan 19, 2013
chrispurs1
  • 372 Answers
SOURCE: brush bar does not turn & makes a loud noise
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Posted on Oct 14, 2007
devocap
  • 201 Answers
SOURCE: dyson vacuum cleaner DC04
I would suggest you invert the vacuum and remove the plate covering the spinning brush assembly. You should check the belt located on one side of the spinner brush to see if it is worn or broken. Also remove anything wrapped around the brush that could be affecting it. Ensure the brush is free to rotate and seated correctly. If the belt is worn or broken, or the spinner brush is unable to spin, replacements are available from a licenced repair facility. I hope it helps! Good Luck!
Posted on Jan 29, 2008
SOURCE: dc17 -too much pet hair around the belt gears
I was having the same trouble and it was driving me nuts.  I tried cleaning and it did not work.  Then I tore the brush assembly off and looked up into where the little tooth gear is.  I saw something that did not look right.  There was a silver roller bearing laying down below the assembly.  I got some tweezers and found it was not attached to any thing.  I then cleaned out the pet hair and saw a spot where this roller goes that takes the slack out of the brush. It is a pain and takes alot of trying with pliers and prodding  with a screw driver, but I got the roller back where it goes.  It does not attach very solidly, but I put every thing back together and it works great so far.  It is a definite design flaw.  I found that you have to keep the main unit on  the floor when the brush is running.  Do not do stairs or pick it up and do couch cushions, that is when the bearing breaks loose.  Dyson needs to figure out a better design for this.  I was lucky to figure it out, but it is very hard to get to.  Again never pick up the unit when the brushes are engaged.
Posted on Nov 28, 2008
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Posted on Jun 07, 2009
Vac Belts
  • 701 Answers
SOURCE: I have a Eureka Altima vacuum cleaner that doesn't
That means that you need to replace the belt. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Posted on Jan 02, 2010
After replacing belt it started making too much noise when you turn on. What could be the reason?
You missed something then.. look further back in the vacuum stream or belt drive area for debris or foreign objects.
Nov 11, 2015 | Bissell Bissel PowerGroom Pet Canister Bag...
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
Hi i have a vax swift complete 1800 watt,it is not picking up and the brushes are not moving they are also tough to move by hand what could this be
Possibly brush needs to be removed , cleaned , brush bearings lubricated, and new belt or oring belt needs to be fitted.
Dont do it yourself unless mechanically minded.
Ring up vacuum cleaner place.
Sep 12, 2010 | VAX Appliances Vax X5 Bagless Upright...
Vax turboforce not picking up
Hello Guest, Please check that your brushbar is turning, if isn't then your belt has broken, once replaced your machine should be fine.
If you need further help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
May 11, 2010 | Vacuums
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Electrolux velocity pet lover 1800
we had the same problem and replaced the driver belt. The only problem is that we seem to have to replace the belt everytime we hoover!
Sep 07, 2008 | Electrolux EL1000A2 Pronto Bagless Stick...
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
