1995 Chevrolet K1500 Logo
Posted on Jan 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Install a 1995 blower motor on Silverado 4x4 truck
Blower motor stops working in high
Thomas Perkins
Level 3:
  • Chevrolet Master 15,088 Answers
  • Posted on Jan 19, 2013
Thomas Perkins
Chevrolet Master
Level 3:
Answers
15088
Questions
0
Helped
3389473
Points
54869
Sounds like your blower motor resister is bad,when going bad,it may not work or not work on all speeds,the motor will work or not,don't think it's motor.Resistor is located next to blower motor,2 screws hold it on,here's what it look's like and where blower motor is.Enlarge picture to see where resistor is.
5 Related Answers
Anonymous
  • 1118 Answers
  • Posted on May 16, 2009
SOURCE: blower motor on my 2003 silverado 2500 only works at high speed I was told it may be the resister If this is true where can I find the resister on my truck THANKS
Chanses are its the resister, it should be located by the heater motor, most are above heater box behind glove box.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Dec 24, 2008
SOURCE: Blower motor stays on high, even with key out
the blower motor speed control module is defective, replace it.
dennymulford
Dennis Mulford
  • 1055 Answers
  • Posted on Feb 18, 2009
SOURCE: 1995 Silverado 4x4 not engaging
check the accuator 59.00 at parts store easy install
Anonymous
  • 81 Answers
  • Posted on May 20, 2009
SOURCE: Blower motor or resistor?
I had a truck about the same year with the same problem, it was the wiring harness, but id check the resistor and the fan first before replacing anythings,
Anonymous
  • 135 Answers
  • Posted on Aug 05, 2009
SOURCE: 1999 chevy silverado heat/air blower only works on high speed
little black box to the left of blower motor (2) 7/32 screws holding it heater box with a plug with 7or 8 wires feeding it the plug is probably going to be melted inside
1helpful
2answers
My 2006 Chevy Silverado 4X4 blower fan stays running after ignition shutOff?cannot control the fan speed either,The display turns on&off every time,settings & bars to show the fan speed work etc.
It sounds as if the blower motor relay is stuck, on your vehicle the relay is part of the blower motor resistor, the resistor is behind the glove box.I hope this helps. Take care. If you have more questions for me about this vehicle or if you just want to say Hi! use testimonial. Thanks
4x4 tied to blower motor???????
Check your fuse box for a bad connection or loose fuse. if all fuses are tightly in fuse box I would suspect a wire on back side of fuse box having a loose connection if this was helpful please leave me a good review
2helpful
2answers
1999 silverado 4X4 took the underdash panel off
probably held in with 6 screws. I have never seen one that just turned a quarter turn to come out.
3helpful
The heater fan on my 98 chevy silverado stopped working... worked on high at first but made a high pitched noise and stopped all together
Run 12V directly to the motor and see if it will run, if it dosent than the motor is bad, if it does than the resister is bad, the resister makes the blower run and also regulates the speeds for the blower, but chanses are if it was making a high pitch squeel before it quit the motor went out.
1helpful
Blower for heater stopped
Remove the hush panel under the dash and unplug your blower motor turn the knob and see if its getting power. If it is replace the blower motor. If your heater seems to work on high but not the other 4 settings. replace the blower motor resistor and pigtail (same general location as blower motor)
1helpful
2answers
Blower problem
The blower motor resistor:
  • is located on the heater core and evaporator core housing near the blower motor.
  • has three resistor elements mounted on the resistor board to provide four blower motor speeds.
  • depending on the blower motor switch position, series resistance is added or bypassed in the blower motor circuit to decrease or increase blower motor speed.
  • has an overheating device (thermal limiter) that will open the resistor coil when the temperature reaches approximately 184°C (363°F) , interrupting the blower motor operation in all speeds except high.
  • is serviced as an assembly. The thermal limiter cannot be reset and is not serviceable.
REMOVAL
  1. Lower the glove compartment.
  2. Remove the screws and position aside the 4x4 control module.
  3. Remove the blower motor resistor.
4 Disconnect the electrical connector. 5 Remove the screws and the blower motor resistor. INSTALLATION
  1. To install, reverse the removal procedure.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
