Question about Tascam DP01 All-In-One Recording Package Microphone
Low volume on finalized songs.
I recorded several songs on my Tascam DP-02. The sound quality of each song sounded great on the sound system I have connected to the unit. I did the mix and burned the songs to CD. Whenever I play the CD in the car or computer, or any other CD player, the sound is really low and I have to turn the volume up a lot! I had recorded each track at a good level and when I did the final mix, the master volume was set high also. What can I do to improve the volume?
  • quirkysongs Feb 16, 2009
    hi joyce! ive been having the same problem with my tascam. after recording and finalizing to cd the volume is so soft that i have to turn the stereo volume ALLLLLL the way up to hear it... and still its too soft! have you had any luck fixing this problem?
    i went out and bought a 200 dollar pre-amp and it doesnt seem to be working out for me. do you or anyone out there have any more suggestions on getting more volume out of the finalized cd?
    i appreciate your help-
  • Keb Wo Feb 25, 2009
    Same exact problem as Joyce.
    Novelist:
  • 189 Answers
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Posted on Jan 26, 2009
How do i get songs from my computer to my tascam dp 02
you can connect wire from computer head phone jack to Tascam recording jack on back of unit.assign track for song to go to,punch play on computer and record on unit. will record song in stereo.
Jul 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
Cant hear audio on tascam 2488i brand new to using it but i do understand how to record a track on my display screen i can see the audio i recorded but no sound what so ever i have my headphones plugged up...
hi
Tascam Digital recording is an effective solution for broadcast-quality home recordings. The Tascam 2488 is a user-friendly tool and useful for home recording situations, especially when writing songs or cutting demos. It even has bus compression and processing for your final mix to give it that "mastered" feel. There are other recorders as well.
Instructions
  1. Learn your gear. The Tascam 2488 DAW offers 24 discrete channels that can be recorded at up to 24-bit resolution. 16 tracks can be recorded simultaneously, via eight XLR balanced inputs and eith 1/4-inch unbalanced inputs. There are several high-quality built-in effects, such as reverb, delay, modulation, compression and a great tool for guitarists: amp and effect modeling. So you can simply plug directly into the console and get live amp tones.
  2. Record or program the rhythm tracks. Most Tascam products offer a large library of built-in drum loops to construct rhythm tracks, so you don't even need live drums just to get a song down. You can designate the tempo of your song from the transport located on the right side of the console; this is where you would use a variety of buttons to make edits, undo or redo and automate punch-ins
  3. Record your base rhythm instrument. Let's say a rhythm guitar. There is a dedicated guitar input located on the front of the console, and once you're plugged in you can use the aforementioned amp modeling features to dial up a sound.
  4. Record the remaining track or tracks. This could include bass, vocals, keyboards, horns or any other instrument. The process is always the same. Arm the track you wish to record on, hold in record and hit play, and the machine begins to record whatever you are playing. When you're done, hit stop. If you want to undo what you recorded, simply hit the undo button.
  5. Repeat these steps on any other instrument you want to record. Plug a microphone into one of the first eight XLR inputs, the first 4 of which have phantom power for studio condenser microphones, arm a track and record.
  • If you need to punch-in a section, you can automate it by dialing up the time in the song you wish to replace using the auto punch function. When you enable this and choose the time in the song you wish to record over, once you hit record and play it'll start the track a few seconds before where it begins the punch-in and it will only go into record when it reaches the designated time stamp.
Do not rush. Proper recording takes time and patience.
hopefully this can help
regards
Jun 11, 2011 | Tascam 2488 Portastudio Multitrack...
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
How do I split up one song on a Tascam DP-02 into more songs?
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
Nov 11, 2009 | Tascam Dp-02cf Digital 8-track Recorder
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
Sound of the recording after burnt to a cd is very low
adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Mar 09, 2009 | Tascam 2488 Portastudio Multitrack...
I cant seem to record more then one song
When you create a new song you switch to the new song automatically. To get back to the old one you just have to 'load' it from the list of available songs. As long as you shut down properly the song you are working on is automatically saved. It will automatically load again until you either create a new song or load another stored song.
bd.
Feb 25, 2009 | Tascam DP01 All-In-One Recording Package...
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
BD
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
554 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
