Question about Dewalt DG7000 Heavy-Duty 7000 Watt Gas Generator
I have a Dewalt DG7000 pull start generator that puts out 75v on the 120v what could be the problem
It is only putting out 75 volts when its supposed to be 120 volts
    New Friend:
Could be the circuit breaker on the generator
Posted on Jan 19, 2013
4 Suggested Answers
protek480
  • 1723 Answers
SOURCE: add electric start to dg7000 generator by Dewalt
This is really not an option. The engine would need a starter motor and battery and starting key switch. You will probably have to replace the unit with an electric start option.
Posted on Jul 02, 2009
puertobori
  • 7733 Answers
SOURCE: My DeWalt dg7000 generator shuts down after
Try clean a clogged carburetor / gas filter!
Posted on Oct 25, 2010
  • 2006 Answers
SOURCE: i have a dewalt dg2900
Does your motor run at the same RPMs that it did before? It sounds like your motor is running to slow to produce the 120V ac.
But it could also be that you have one or more diodes blown.
Since the generator is selling for $1,100.00 on several sites, make sure that you don't spend more for repair parts/labor than what you can replace it for.
Anything can be repaired, but some aren't economically repairable. So if you have to pay someone to work on your generator, it might be better to replace han repair.
Posted on Jul 08, 2011
Have a 1200e true life gen.only putting out half the voltage.
I've repaired a few modern generators and have not seen a diode go bad yet, its usually a capacitor or wires rubbed through (broken off from vibration)...also if there is two circuit boards, either one could be bad or just a wire to them
Sep 24, 2014 | Cars & Trucks
Why do i only have 94 volt output on dewalt generator 2900 watt
It should change with the load, the more load you put on the line the magnetic field increases with the amperage and the gen will produce more output until its rating is reached. This happens especially if it has been sitting a long time.
Aug 15, 2014 | Dewalt DG2900 Heavy Duty 2900 Watt Gas...
Have a 75 w halogen and want to replace with a larger led that would fit or fit over my wall niche
If it currently has a ballast, dismantle it and rewire so that a full 120 volts goes to the bulb holder and then put in the led bulb of your choice.
Nov 08, 2013 | Blue Wave Nichless Pool Light for In...
LG 4801CW won't give hot water
suggest you put a new water inlet valve in it .
Sep 02, 2017 | LG Washing Machines
Hi there. My Maytag MSE 760 FARS dishwasher is not filling, but the heating element is working. I suspect the pump has failed. What do I do?
what you can check,
  1. the float in the tub.their may be something caught under it
  2. the water valve,use a meter set to check ac voltage and check for 120 volts ac at the plug to it,if has 120 when supposed to fill valve is bad so long at it has water supply to it
  3. the float switch,use meter set to lowest ohms setting and remove the 2 wires on float switch and check for continunity(zero ohms) if meter reads OL replace float switch
  4. the control,check for 120 volts ac to float switch when supposed to fill, if 120 at fill portion yet no fill ,replace control
  5. water supply,if uses flex tube something in cabinet under sink may have pinched water line
Good luck,i hope this helps
Gene
Aug 02, 2011 | Maytag Dishwashers
How to remove the glass cover on a 5tv52whd ceiling fan and where i can buy the bulb
Regards, Tony
May 11, 2011 | Monte Carlo 5DI52WHD Discus White Ceiling...
My transformer is burned.Now I need to know what the secundairy voltages are
Transformers USUALLY don't get burned as they are usually protected by a fuse. This one supposedly uses a 3 amp fuse which should have protected it from getting burned. If you can find a schematic or if you can find the specs on the output amp power supplies we can probably calculate the voltage of secondary. We know only that it is supposedly 120 Watts and uses an 8 ohm speaker. The RMS voltage should be about square-root 120*8 = sqrt 960 = 31V*1.4 = approx 44 volts peak... so you will need to get about +/-45 volts out of the supply for headroom... which will need approximately 34 volts AC given diode drop and droop of filter caps. These are really rough educated calculations from the tiny bit of info we have.
Finding a transformer to replace this matching these requirements will be near impossible without getting device from the original manufacturer OR having your rewound.
I would first verify the transformer is bad (only plausible cause is somebody over-fused it or a winding shorted)... Remove all the secondary loads. Put a 3 amp fuse in AND put a 60 Watt light bulb in series with teh power cord to act as a limiting device to test the transformer... Note that transformers DO have a bit of odor as they are usually impregnated with a varnish...
Jan 11, 2011 | Hartke Kickback 12 Bass Amp Warehouse...
My generator is not putting out the proper voltage? it's only putting out approx 75 volts on the 120 volt circit. i adjust the idle to full out and i get approx 112v.
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
Aug 09, 2010 | Northstar Electrical Supplies
Dewalt DG7000 Heavy-Duty 7000 Watt Gas Generator Logo
215 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
