Question about Kenmore Washing Machines
Washer starts but no water goes in
Model 110.29822800 type 111-05
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
You will need to replace the water inlet valve. Here is the part to order.
Posted on Jan 19, 2013
Whirlpool Cabrio washer model WTW6200SW, when the wash cycle is started, starts filling with water, after roughly one minute the machine stops than goes into spin cycle, will spin for a short time than...
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
Nov 01, 2013 | Washing Machines
Whirlpool washer model ICWTW474OYQO Type 587-08
My I have a whirlpool washing machine Model # WED4850XQ0, Type 587-08, it fills up with water, but when it start to agitate, it starts to smoke.
Jun 19, 2013 | Washing Machines
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Which compartment is for popwder and which for conditioner
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Methinks you could also do with a manual!
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Cheers,
John C
Mar 25, 2011 | Hoover PE235 Front Load Washer
I need to know what goes in what compartment for the detergent, softner and bleach. I do not have handbook
Manual first!
Which tray?
In a few cases I have come across the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Cheers,
John C
Mar 18, 2011 | Avanti W1092F Front Load Washer
How do you load detergent into the Bosch axxiss washer
I'm assuming you are not quite clear as to which tray is which-
A quick way to find out is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
I think you also require an operating manual-
Cheers,
John C
Mar 06, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Which slot do i put the fabric softner into and which slot do i put the washing powder into?
A quick way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
For a manual you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Cheers,
John C
Mar 05, 2011 | Whirlpool AWM5104/1 Front Load Washer
Water goes into the washer (model GHW9150PW0)
your inlet vaulve is sticking and allowing water to trickle through, only solution is to find if it is your hot or cold vaulve and replace it
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
