Question about Health & Beauty
How to change blades on HC221K hair trimmer - Health & Beauty
  • 13 Answers
SOURCE: Replacement Blades
I dont believe you can get replacement heads for non-professional clippers. If you are going to invest in a new pair you could go to Sally's Beauty Supply and purchase a pair that you could always get a replacement head for.
If you dont want to invest in a new pair you could bring that pair in there and see if any of the replacement heads they have may fit. There is usually eather 2 or 4 screws that will go in there. You could find one that looks the same and it may just work! Good Luck!
Posted on Jan 09, 2009
SOURCE: how do I change the
What is missing in the "solutions" is the fact that you need to raise the bar with the guides on it that is part of the trimmer.  Depending upon how you removed the existing blade, the bar may be flat against the trimmer.  Take a flat head screwdriver and raise that guide.  Slide the new blade on and line up the slot at the cutting edge of the blade.  The whole problem is that the guide is likely flat which makes it impossible to install the new blade.  VERY POOR directions from Oster.
Posted on Jul 04, 2009
SOURCE: HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Posted on Jul 27, 2009
  • 12 Answers
SOURCE: Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Posted on Aug 11, 2009
  • 10865 Answers
SOURCE: Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Posted on Mar 25, 2010
What may be cause for trimmer's unusual noise?
Have you lubricated the blades? You can buy spray lube (Remington Shaver Saver) for this purpose.
Feb 11, 2015 | Remington HC-921 Hair Trimmer
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
How do I change my blades?
unscrew the blades and replace with new ones, alternatively oil the blades that are already on the clipper each time it is used. You will be surprised at the amount of hair clogged up on the inner blade when you take them off
Aug 05, 2009 | Conair HCT-426 Hair Trimmer
Jul 17, 2009 | Remington HC-600 Hair Trimmer
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
I have the alpha 8554. I dont like the plastic combs, is that the only way to adjust closeness?
No, the type of blade you have can be adjusted or change to a closer type blade. This blade is inter-changeable but you need a special tool to restt the blade or change the blade for the type of hair cutting you want.
Call Mannys Sharpening 323 263-4697
Jan 04, 2009 | Wahl 8554 Hair Trimmer
How do I change the blade on an oster 76 hair trimmer
Sep 12, 2008 | Oster 76076-010 Hair Trimmer
How do i change the blades
Have you tried having the blade running when you slide it back in?
Aug 08, 2008 | Oster 76076-040 Hair Trimmer
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Dec 06, 2007 | Andis Outliner II Hair Trimmer
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
