Question about metacafe.com
Exception edomparseerror in module - metacafe.com
Login Exception at Metacafe pro 1.4.2
Get that off there immediately! It's BAD.
"Metacafe is a kind of malicious programs that is setup on computers and seeks information about users without their attaintment. Metacafe is known to transfigure PC settings resulting in sluggish connection speeds, diverse home web pages and waste of global Internet or lock down of other softwares creating a requirement to remove threat with special removal tool."
It is here:
http://www.securitystronghold.com/gates/link/0/2/?url=_d1_MetacafeRemovalTool.exe
The program protects your computer against this Metacafe virus that harms your computer and breaks your privacy. It can scan your hard disks and registry and destroy any manifestation of Metacafe.
If it's been on there too long, it may of screwed up important files. You can then try going to command prompt (just use run on the start menu (type cmd in the run box), or going to start menu, then All programs then accessories and choose command prompt) and type sfc /scannow. That should repair any damaged system files. If that doesn't work, you can try a repair disk if you have an original operating system CD, if all else fails get your important stuff off there and reinstall. Hopefully it hasn't done any damage, but get metacafe off there asap!
May 29, 2013 | Computers & Internet
I got a E025 in my new casio cash register TK 3200 and the manual does not has the meaning for it
Problem signature
Problem Event Name: BEX
Application Name: msnmsgr.exe
Application Version: 14.0.8089.726
Application Timestamp: 4a6ce533
Fault Module Name: unknown
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 06198860
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Oct 02, 2009 | Casio Parts Cash Register PC Desktop
Lenova computer running Vista crashes most applications. Two examples: Family Tree Maker: Problem Event Name: APPCRASH Application Name: FTM.exe Application Version: 18.0.0.86 Application...
Weird category.  Seems OS- or program-specific enough.
The exception codes are supposed to give you insight into what's going on, (Intel exceptions C000 00029 and E043 4F4D in the context of Vista or your CPU in particular, say) but perhaps you should try the Vista equivalent of WinXP's RunAs options, where you can run them as older applications and dodge some incompatibilities.
Similarly, you might want to create a VM (or runtime jail; many, many options to be had there...) and try it in that context, so that if the program's spoiling things at least your system won't need to worry or crash.  The easiest thing of course is to find updates of those programs that promise to play well with Vista.
Aug 22, 2009 | Computers & Internet
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
T is constanly coming when i play brian lara cricket 07..i'm having windows vista ultimate.is there any solution to this prob.If so pls send it to me as soon as possible. Problem Event Name: APPCRASH ...
Problem signature:
Application Name: ICC2007.exe
Application Version: 1.0.0.1
Application Timestamp: 21444c52
Fault Module Name: ICC2007.exe
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 21444c52
Exception Offset: 001212f0
Locale ID: 16393
Additional Information 1: 8a65
Additional Information 2: a977d7b616fbef91d447986a1e395fda
Additional Information 3: 902c
Additional Information 4: d3100cb634d31eedbe4c3e2cdaa33f77
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
when i play brian lara 2007 it shows this error plz help me
Mar 13, 2009 | Codemasters Brian Lara International...
metacafe.com Logo
321 people viewed this question
Top metacafe.com Computers & Internet Experts
David Payne
David Payne
Are you a metacafe.com Computer and Internet Expert? Answer questions, earn points and help others
