Question about Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow
Debris is not going in to the canister and the wand is constantly suctioning even when not in use
  • Les Dickinson
    Les Dickinson Jan 19, 2013
    you can get the part here http://www.vacpartswarehouse.com/Dyson-D...
  • Linda Hill Jan 21, 2013
    Thank you for your help. I don't see anything broken or missing on the undercarriage.
  • Dyson Master
  • 18,391 Answers
It sounds like The undercarrage assembly needs replacing on your machine..
If you stand behine the machine and look at the undercarrage you will see a small arm on the extream left hand side that extends from the same part that holds the back wheels.
On the end of this arm thier should be a small knob that turns the internal valve from hose to floor suction. if it is broken it won\'t change over and will either suck only thru the wand or the brush bar depending on when it broke
Bellow are two pics the one of a new undercarrage assembly ( top one)Screw driver pointing knob out
the bottom one withthe knob missing Debris is not going in to the canister and the wan - index.php?action=dlattach;topic=388.0;attach=299;image
Posted on Jan 19, 2013
3 Suggested Answers
Dysonteam
  • 167 Answers
SOURCE: Dyson DC07 bagless - upright mode v poor suction, wand mode ok
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
SOURCE: hi my dyson dc18 has great suction from wand but
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Posted on May 23, 2010
It does not have the suction to pick up like it did.
Check hose, wands, power nozzle for blockages.
There is a screen located at the bottom of the bag well. Make sure this is clear of debris.
There is a possibility the motor is wearing out and needs replaced.
Feb 07, 2011 | Electrolux C101 Bagged Canister Vacuum
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
Dyson DC17 Animal does not have enough suction from the wand handle to power the mini turbine head. The wand handle has very little suction.
It sounds as though your wand/hose assembly is blocked. Try following the blockage procedure in your user guide or visit our website's support section where you can use our self help guide to diagnose problems.
www.dyson.com
Kind regards
Darran
Mar 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Hoover Windtunnel Canister Belt
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
No suction to the canister
Sounds like you have a blockage somewhere. I would take the hose off the canister and test for good suction. if ok then you have an issue with the hose and wand assembly. follow this to determine where you lose suction.
Oct 20, 2009 | Vacuums
No suction or spews debris
There is a blockage somewhere in either the hose, the powerhead, or the extension wands. Check to see if the bag is full.
Mar 07, 2009 | GE 106766 Bagged Canister Vacuum
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
My DC05 Dyson suction has stopped...there are no blockages, the seals are good, there seems to be more suction coming from a yellow box which is situated at the top of the removable cannister. There is...
My Dyson had exactly the same problem. I found the problem was caused by a blockage in the hose. Take the hose out where it joins the cleaner (it will come out if you pull it downwards gently) and take the hose out of the handle by squeezing the yellow buttons on either side. I pushed a rubber alkathene pipe down and found a piece of plastic was blocking it even though at first I was sure it wasn't blocked.
Jan 11, 2009 | Dyson DC05 Cylinder Bagless Canister...
Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow Logo
61 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
