Have a lg 47lm670t and have connected all scart leads but only get coloured lines. Please help as brand new tv!!!! Thanks Stuatt
    Genius:
  • 1,669 Answers
BRING IT BACK AND GET A NEW TV!!! It is messed up!
Posted on Jan 19, 2013
SOURCE: lg 42px4dv - speckly screen
im having this problem to
how do you upgrade the software in the tv?
thanks
Posted on Nov 28, 2007
shanth
  • 108 Answers
SOURCE: fault
1.the problem in your video processing circuits present inside your tv
2.if you have user service activation through remote controll. Check your manual if you have that facillity
3.the problem may be due to the incorrect IF tuning .check horizontal and vertical frequency
4.Problem with the bad Tuner
Posted on Dec 20, 2007
Siliconchip
  • 52 Answers
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Posted on Jan 05, 2008
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
SOURCE: no sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Posted on Jul 04, 2008
When playing videos the dvds are in black and white. The sound is fine the tv itself has colour
hi if your using scart lead make sure it's tight fit or change the lead, or change it to another scart connection. thanks
shaun
May 27, 2017 | Televison & Video
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
LG 65LM6200 humm and lines
Bad scart connection or need new stronger scart lead
Jan 24, 2013 | LG 65LM6200 65" LED HDTV TV
I have setup a goodmans freeview box model No GDB12X1T to a tv with a scart connection as the setup leaflet shows.The box pulled in a lot of extra channels,but the signal strength on the first time...
hi make sure the scart lead is a tight a fitting also make sure the aerial lead is not to long as you will loose signal strength , thanks
shaun
Jun 15, 2017 | Televison & Video
How do i set up my plasma tv just to watch sky on the tv i was given a tv pioneer pdp-42mve1 and have got the power lead and a lead with a scart and 6 push in leads coluers are green blue blackyellow red...
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
Hope this Helps
Little Dish Fitter.
Sep 02, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Televison & Video
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sir I have just acquired a Sony DVD recorder model no. RDR-GX350. I have an LG LCD TV and a Sky HD Box and I have connected the recorder to the TV with an 'S' lead and I can play a DVD, I can't set up the...
Thanks, but no thanks, in the long run it is better to get a technician in to sort it, more expensive yes, but not so traumatic as trying to deal with someone by typing in answers to questions, the man I dealt with assured me I had two scart plugs on my TV. I only have one, so he said it can't be done, end of story.
Aug 28, 2008 | Sony Televison & Video
Verticle lines
You should connect your TV to an Active DtH Connection or a Live TV Cable or even to a working DVD/VCD Player etc. and tune it to the frequency of the same and it should start working. If it doesn't, please contact Service Center.
Jun 18, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
