Setting up internet access on computer just restored to factory setting
I just restored my dell computer to factory settings. How do I now reset up to internet. I use verizon as my provider
  • 27,725 Answers
Wireless Internet connection
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Posted on Jan 19, 2013
  • Bob Foltz
    Bob Foltz Jan 19, 2013
    I do not have the wireless internet icon on the desktop or lower right hand corner. Where would you start without icon?
  • Brian Sullivan
    Brian Sullivan Jan 20, 2013
    so this is a desktop computer If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done.
rtrahan
  • 741 Answers
SOURCE: how to restore factory settings
Best bet is to do a system restore to a date before you have problems. Go into start>accessories>system tools>system restore. Your computer automatically creates restore points each time you log on..so once you are in system restore just pick a date that was before you had problems and your system will restore itself to that date...if you have any questions let me know..there are other options if that does not work so keep me updated..
Please rate with 4 diamonds.
Posted on Mar 06, 2009
Murphybanton
  • 2004 Answers
SOURCE: want to restore back to factory settings
Restart the computer and hold down the F11 key. You can also backup your documents in the process of the restore.
Good.
Rate this fixya
Posted on Apr 15, 2009
  • 3940 Answers
SOURCE: reset to factory settings
If the system has the original Dell image, then just after the Dell Bios splash screen should be a black screen with w blue bar at the top with www.dell.com at the top.
At that screen press CTRL + F11 to initiate the PC Restore program.
Posted on Apr 16, 2009
sijudoniston
  • 134 Answers
SOURCE: ibm restore to factory setting
The below link will solve your problem
http://www.intrepid.com.au/how-to-change-your-windows-xp-product-key-without-reinstalling/
Posted on Aug 27, 2009
SOURCE: howcan I restore my Dell Mini Notebook to factory
You can restore your Dell Mini using Using Dell PC Restore in Windows XP or Dell Factory Image. You can successfully restore your computer yourself. All you need is to download a manual containing instruction on how to restore. Download the manual from http://support.dell.com/support/edocs/systems/ins1010/en/index.htm
See pages from 37 - 43. You can restore your computer on your choice.
Cheers!
Posted on Apr 01, 2010
How can I restore a Dell laptop to the factory default settings?
Here are the main steps to restore your Dell laptop to its factory settings. Depending on the model you own, the procedure may vary slightly.
Before beginning, please note that by restoring your computer to its default factory configuration, all data on the C drive will be deleted. We highly recommend backing up any personal files before moving forward with the reset.
Hard Reset Dell Laptop Restart your computer by clicking Start > arrow next to the Lock button > Restart.
As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
Note: You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Press the Down arrow to select the Repair Your Computer option on the Advanced Boot Options menu, and then press Enter. Select your language settings and then click Next.
Log in as an administrative user, and click OK. Then click the Dell Factory Image Restore option.
In the Dell Factory Image Restore window, click on Next. Check the box that reads Yes, reformat the hard drive and restore system software to factory conditions, followed by Next.
The computer will now restore to its default factory settings. Once the restore operation is completed, click on Finish to restart your computer.
Feb 27, 2017 | Dell Computers & Internet
Where is the reset button on a dell e5400
There is no reset button. If your notebook is frozen and will not turn off, hold the power button down for 5 seconds.
If you meant to reset (restore) to factory defaults, see this.
Restore Dell Laptop to Factory Settings
Caution: This will wipe out your data.
Feb 06, 2017 | Dell Computers & Internet
Factory reset on my laptop
Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting. This utility is convenient because you're not forced to use the Windows startup CD to restore your computer.
Step 1: First backup all your important data and restart your computer.
Step 2: Press 'F8' if you are using Win7/Vista or 'Ctrl + F11' if you has Win Xp. 'Advanced Boot Option' menu options will be opened.
Step 3: Choose 'Repair your computer' from the 'Advanced Boot Options' from the menu and press 'Enter'.
Step 4: Select language setting and press 'Enter'. Now Login window will be appeared.
Step 5: Now login as administrator to continue the factory reset process.
Step 6: Click 'Dell Factory Image Restore' followed by the 'Next' button.
Step 7: Choose the check box marked 'Yes, reformat disk drive and recover system software to manufacturer condition'. Once the check box is chosen, simply select the 'Next' button and your Dell computer/laptop is renewed to factory setting.
Step 8: Press 'Finish' once it has been done. ...
This process will erase all your previous changes that have been made to the Dell computer and reset the configuration settings to factory setting.
Feel free to get technical assistance anytime at http://www.vtechsquad.com/dell-support/
May 26, 2012 | Dell Inspiron 1521 Notebook
How do I reset to factory settings without the disk
In order to reset your computer to Factory default settings without the disc, you can follow the instructions below.
1. Turn on your computer. Once you see the DeLL Logo Press and Hold the CTRL button then while holding CTRL button, press F11
2. You should see the Dell PC Restore by Symantec application.
3. You can click Restore and Confirm the restoration.
4. It will take 10-15 minutes. Once your computer rebooted, it should already be in the default settings
Apr 04, 2011 | Dell Inspiron 1501 Notebook
How to restore my laptop to its factory settings
Proir to restoring computer devices, ascertain that resources that would require backup is securely preserved. For example, computers loose resources least complented by the manufcturer with restoration to factory settings. Also significant is consulting with technician to ascertain the condition of device that least require facory settings. Usually a condition is resolvable with an alternate means least requiring factory settings. Prior arrangments that make restoration attainable includes acquiring the tool resources either as disk roms that contain programs. Usually the computer manufacturer would have provided the restore resources either as disk roms either CD or DVD. Recent computers however have built in programs restore media in which instance restore is possible without disk roms materials. Depending on the condition of the computer considering recent innovation would either require disk material to attain restore or builing functions. Usually refering to the computer support experts with conditions that are encounted would attain means to resolve.
Feb 19, 2011 | HP Mini 210-1030NR Netbook
I have a Dell Inspiron Mini Laptop 1012, how do you set it to factory seting?
You will lose all your data if you wanna set it to factory setting ,have its back up before you loose it.
Here is how to restore at Factory Setting..
1: Restart the computer, click Start, click the arrow next to the Lock button, and then click Restart. 2: As restarts, press the F8 key until the 'Advanced Boot Options' ,menu appears on the screen.It should come up before Window logo appears. 3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. 4. Specify the language settings that you want, and then click Next. 5. Log in as a user who has administrative credentials, and then click OK. 6. Click Dell Factory Image Restore. 7. In the Dell Factory Image Restore window, click Next. 8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. 9. Click Next. The computer is restored to the default factory configuration. 10. When the restore operation is completed, click Finish to restart the computer.
Jan 05, 2011 | Dell Inspiron Mini 1012 Netbook...
How do i restore my dell latitude c600 to its factory settings
The Dell Latitude C600 is an older Dell laptop computer. This particular model came with Windows XP pre-installed on it. If you are experiencing problems with your computer, or you want a fresh start with your Dell, you can restore the laptop to factory settings. This process removes all of the data saved on your computer and resets all of the settings back to the way they were when you first purchased the computer.
Instructions:
Step 1
Turn off your computer if it is currently on.
Step 2
Turn on your computer. When the Dell splash screen appears, hold down "CTRL" and "F11" on your keyboard. Release both keys at the same time.
Step 3
Click "Restore" in the "Dell PC Restore by Symantec" window. Click "Confirm" when you are warned that all data will be lost.
Step 4
Allow the system to restore and wait for the message that says "The system recovery process was successful." This can take about 8 to 10 minutes.
Step 5
Click the "Finish" button and your Dell Latitude D600 is restored to factory settings.
May 10, 2010 | Dell Latitude D600 Notebook
How to restore to factory settings
You Hit F2 when The Computer Is Booting Up then You Go into The BIOS And Somewhere In there It Should Give you The Option To Set the Computer Settings To Defalt.
Jul 18, 2009 | Dell OptiPlex 740 PC Desktop
How to get factory settings for my Dell Inspiron 1505
If you have Windows Vista you can press F8 while booting to access the Windows Startup Repair and then select the Factory Image Restor.
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
