Question about Hampton Bay 73554 Antigua Ceiling Fan
Light turns off
When i turn switch on, the fan starts fine but the light comes on for about three seconds and turns off. After a while it stays on. I already switched the light bulbs.
  • 51 Answers
Wiring is faulty (probably in fan unit itself), have it checked straight away.
Posted on Jul 25, 2007
SOURCE:
2004 olds alero 3400 eng.turn on key and all warning lights and gauges come up,then all goes off after 3 seconds,starter will not work,can start by jumping across starter and runs fine and shifts fine
Check for power at the switch wire when someone turns the key to start. I would say there is a break in the circuit of the thin wire between the starter & the ignition switch
Oct 03, 2012 | 2004 Oldsmobile Alero
I've had my Carriage House II ceiling fan for three weeks. Yesterday when we turned the light on it stayed on for a second or two and shuts off. It now does that every time we turn the light on. Even...
Check the bulb(s) to make sure they are screwed in securely. If it happens only when the fan is on, there may be a loose wire up in the housing, where the light fixture attaches to the fan. Perhaps, a wire nut is loose. If the light and the fan switches are wall mounted separately, the wall switch for the light may be bad.
Feb 05, 2011 | Hampton Bay Heating & Cooling
I have trouble starting my van and later on the check light came on (P1607). The car can no longer start but sometimes when I fiddle with the battery it would start up again and when it does it runs fine....
P1607 means "powertrain control module (PCM) internal circuit malfunction". According to the factory service manual, a low battery condition can cause this. This code can also pop up after the battery has been jump started.
You need to reset the PCM. To do this, turn the ignition switch off. Remove the No. 13 fuse (7.5Amp) from the passenger's under dash fuse/relay box for at least 10 seconds. Put the fuse back in. That should complete the reset.
Now to check again for the code: turn the ignition switch to on (not start.) Wait 30 seconds. If the check engine light stays OFF, turn the ignition switch off and wait 10 seconds. Turn the ignition switch back to on (not start). Wait 10 seconds. If the check engine light stays OFF, you had an intermittent fault and it has now been reset--everything is fine. If the check engine light comes back on during these checks, have the code that set read out. If the code is P1607 again, then you may have to have the PCM tested at the dealership for an internal fault.
Feb 04, 2011 | 2002 Honda Odyssey
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
GMPO75-3 Pilots won't light
vent motor should come on, a few seconds later the glow plug or ignitor shoul start glowing or sparking, if vent motor comes on check and make sure pressure switch is clicking, check pressure switch hose at switch and vent motor and make sure ends are not clogged
Oct 27, 2009 | Heating & Cooling
My ps3 wont turn on
Hi There,
Your Processor needs reflowing (re soldering on the board) as the system over heated, it caused stress on the solder joints underneath.
Sony charge £150 and give a month warranty to repair it.
We charge £60.00 and give a 6 month warranty.
FixMyConsole
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Hampton bay fans
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Jun 04, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 73554 Antigua Ceiling Fan Logo
176 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
