Question about Nikon COOLPIX P90 Digital Camera
Zoom control not responding
Hi, The small zoom control on top of the camera turns but the zoom does not change. Any suggestions appreciated! Thanks
    Genius:
  • 1,019 Answers
Well there is only one suggestion I can make and it is the camera needs service / repair by a shop.
Posted on Jan 26, 2013
  • Frank
    Frank Jan 29, 2013
    Hi Russell and thanks for your comment. I guess that's probably the only thing I can do. Thanks again.
bmwrider
  • 215 Answers
SOURCE: stuck on zoom
I love this "just take it to the shop" It sounds as if there is a piece of foreign body in the lens drive mechanism and it's stopping the lens from fully extending. Or perhaps the sensor which tells the canera the lens is at the end of it's zoom is faulty. Those are the hard ones. The easy ones are maybe a loose flat ribbon cable connector. With a bit of vibration and jarring it's possible one leading to the lens is loose and just needs cleaning and resecuring to it's socket. I've got the same model here and perhaps it has the same problem. Open the camera and look at the lens assembly. Running on the left of the round piece is a flat ribbon cable. It makes a sudden 90% drop in one spot and the one I have was fractured at that position. Thereby disabling both the extend and retract sensors. The problem there, is just for a lousy piece of wiring you have to buy the complete assembly at a cost of $299 AUD plus freight. If you have a very fine soldering iron, steady hand and very good eyesight you could possibly fix it yourself. Good Luck BMW BMW
Posted on Jul 28, 2006
SOURCE: Nikon coolpix 2200 zoom
Based on your description, it certainly sounds like the zoom button is stuck or shorted. If you're comfortable with taking it apart, I'd try getting to the zoom electronics and see if there's any noticeable damage. Whenever I try something like this, I like to see how much damage I could cause first. eBay has sold this item for less than $50 with shipping (just in case you break something). You can also look there for parts cameras -- one listed for $10 with free shipping that might give you what you need.
Posted on Aug 21, 2007
ctf1800
  • 4402 Answers
SOURCE: A spot appears in same location on every picture
take the lens out and blow air inside the camera and on the inside part of the lens.
Posted on Jan 10, 2008
pauman
  • 248 Answers
SOURCE: zoom lens broken nikon coolpix L1
hi
the lens alignment is messed up you can try to push it while slightly turning it or slap/tap the sides of the lens to fix it...
Posted on Aug 11, 2008
Roynice152
  • 88 Answers
SOURCE: dropped camera jammed zoom lens on nikon 28-85 lens
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Posted on Jan 09, 2009
No zoom without battery without play pause
hi
If the battery is weak, must replace with a new one, zoom struck open the cam check the zoom motor on the camera section give a little lubrication to loos it, if the motor not working replace it.
Feb 21, 2016 | Sony Handycam CCD-TRV68 Camcorder
My zoom just stopped working could this be a setting someone changed on the camera?
if the zoom stopped working so there is a mecanical problem, if you try to use the zoom and it does not respond so service is required to get the zoom working properly.
Dec 24, 2010 | Canon PowerShot S3 IS Digital Camera
Zoom--mm blinking and can't change mode
Your zoom motor is probably stuck. Remove the two screws on the front side of the tiltable head. Pry off the two tilt caps using a small flat head screwdriver (they are glued on). Remove the 4 screws found under each cap. Now you can separate the two sides of the head and take out the two lenses (remember exactly how the lenses were positioned). Try pushing the flash in or out (it should move with a little force). See if the flash now responds before reassembling.
Mar 21, 2010 | Canon Speedlite 430EX TTL Flash
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Top control touchpad not working plus zoom extending.
Its problem of that loading flap (technical name is control switch block) and requires replacement.
control switch block is included play-stop-rew-ff-eject etc switches including zoom-wide switch.
Jun 21, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
Zoom will not go back when i power off, comes up zoom error
My camera was dropped and the zoom small stick stop working, looks like it was stuck, when I want to zoom I pull de stick but it doesnt work, any suggestions?
Apr 04, 2008 | Cameras
Nikon coolpix 2200 zoom mechanism
If the lens assy is not responding to zoom buttons then the camera is in confusion mode due to a sensor being blocked or defective. Normally it would go thru a startup cycle to initialise position of various parts in the lens assy and give back control to you but in your case it is not getting that signal and in your case I would bet on the end sensor.
Nov 08, 2006 | Nikon Coolpix 2200 Digital Camera
Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Oct 18, 2006 | JVC Handycam GR-DX77 Mini DV Digital...
Nikon COOLPIX P90 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
