Question about HP OmniBook XE3 Notebook
Windows\system32\hal.dll. corrupt The procedure entry ponit regset key valuew could not be locatend in the dynamic link library advapi32.dill
  • HP Master
  • 27,725 Answers
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP
Method 2
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed:Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 3
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Posted on Jan 19, 2013
EngineerGR
  • 119 Answers
SOURCE: windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Posted on Mar 28, 2008
SOURCE: Warning on boot: savedump.exe Entry Point Not Found"
Sell it to me I can buy it ? If you wan`t Let me the cost ?
swapneshmali@hotmail.com
Posted on Jan 31, 2009
parrotheadpc
  • 2600 Answers
SOURCE: i have a hp dv7-1468nr and im getting this problem
At the start button, choose run. Type MSCONFIG in the text box and hit enter. Choose selectice startup and go to the startup tab. On the startup program list, scroll down until you find an entry for TVagent, uncheck the program so it will not load immediately until it is needed. Click apply and ok to restart the system. You can also disable auto start for other programs as well.
Posted on Nov 14, 2009
  • 3940 Answers
SOURCE: TVAgent.exe - Entry Point Not Found The
TVAgent is a Cyberlink software for HP machines. It's used to use computer as a TV. If you do not use it, you may want disable it or uninstall it.
If you do use it, uninstall it and then download and install the new package for the HP MediaSmart TV it is SP42505 dated 3-2009
Posted on Nov 26, 2009
  • 5 Answers
SOURCE: TVAgent.exe entry point not found always pops
try to re-install windows installation cd/dvd and all drivers that came with computer....this should automatically re-install the correct entry point processes into laptop.....make sure you back up all of your settings and documents,pics etc on dvd/cd first incase windows automatically formats over them...
Posted on Jun 12, 2010
CoD2SP_s.exe entry point not found
the procedure entry point _AIL-3D-provider_attribute@12 could not be located in the dynamic link library mss.32dll.
Mar 03, 2012 | Activision Call of Duty 2 for Windows
Cannot open program , get the following message: Procedure entry point cannot be found V@YAXPAX@Z in dynamic link library msvcrt.dll.
The message you are getting indicates the the copy of msvcrt.dll is not compatable with the program you are running.
By the way msvcrt.dll stands for Microsoft Visual C Runtime Library and is a 'dynamic link library' in case you were wondering.
I would recommend one of the following:
1: Contact the programs publisher and ask them about this issue and what version of this library IS compatible with your program.
2: Find the version of the copy of msvcrt.dll you have by going to C:\windows\system32\
find msvcrt.dll, right click on it and click on the 'Version' tab and write down the version number.
Go online and acquire a newer version of msvcrt.dll and place it in C:\windows\system32\
Jun 20, 2011 | Computers & Internet
How to install mss32.dll for igi 2 ?
i got this error while running the igi2 game after copying the mss32.dll file to system32 folder."the procedure entry point_AIL_set_3D_sample_distances@12could not be located in the dynamic link library mss32.dll."please help me with this
Dec 11, 2010 | Computers & Internet
How do I find and install a missing file from windows?
  1. Download and install DirectX 9 here.
  2. After install of DirectX 9, restart your computer in safe mode.
  3. Next, delete d3d8thk.dll from the c:/winnt/system32 folder.
  4. Then copy this d3d8thk.dll (originally d3d8thk.w2k) to "c:/winnt/system32/d3d8thk.dll" and restart.
Jul 13, 2010 | Microsoft Windows 2000 Professional for PC
Rundll32 exe-entry point not found the procedure entry point_except_handler3 could not be located in the dynamic link library vmsvcrt.dll
Just visit this site...
http://www.fix-all-dll-errors.com/vmsvcrt.dll/
this will help in case of missing or downloading dll's .
helped in my prob. :)
Jan 11, 2010 | Computers & Internet
The procedure entry point check token membership
You Must have a Copy Of the windows you use!
Put the CD of that copy in the C D driver..
Go to Run write ( cmd )
you'll see a black screen..
Write sfc / scannow
It will replace all your dll files.. It will take 30 to 60 minutes!
Oct 12, 2009 | Acer Aspire L100 PC Desktop
Won't boot/reboot after turning off yesterday
1. boot from a Windows CD and go for the repair option.
2. Copy usp10.dll from c:\windows\servicepackfiles\i386\gdi32.dll to c:\windows\system32\usp10.dll. (Do keep a backup copy of the old usp10.dll in c:\windows\system32 directory )
3. Reboot normally
http://www.aa1consulting.com
Jul 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
to produce entry point _except_handler4_common could not be located in the dynamic link library msvcrt.dill
Apr 19, 2009 | Microsoft Windows XP Professional
What does this error message mean?
It means you've got a corrupted file.
This is usually is a malware that is deleting the js3250 file.
"Go to C:\Windows\System32\ipv6monl.dll and delete it. Reinstall Firefox and it will work fine."
May 26, 2008 | Microsoft Windows XP Home Edition
Windows>\system32\hal.dll. corrupt
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
HP OmniBook XE3 Notebook Logo
80 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
