Question about Microsoft Windows XP Home Edition
I am running in safe mode, I computer will only let me go back one day, this problen started ten days ago.
  • Microsoft Master
  • 27,725 Answers
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. If you need more help with this post a reply
Hope this helps.
Posted on Jan 19, 2013
4 Suggested Answers
techniwiz
  • 275 Answers
SOURCE: Windows start login problem
do u have any other user which is an admin user?
and what happenes when u try to start system in the safe mode?
Posted on Nov 01, 2008
vkyhunk
  • 156 Answers
SOURCE: computer wont start in safe mode
Click On Start---> Run---> MSCONFIG---> click on BOOT.INI --> Then Click On Safe Boot --> Click Apply And Click Ok---> Restart Your system u'll get what u want.......... Temme If u need any help in virus removal...
Plz Rate This Solllution If It Works For u
Posted on May 21, 2009
  • 1481 Answers
SOURCE: i had my laptop fixed 6 months ago and i was told
who ever fixed your laptop must has done some thing that has led you to this issue....it's just not possible that you wont have Safe Mode, it's one of the inbuilt safety system of Windows OS....press F8 to get into the option to go to Safe Mode or.....Normal mode of operation.....
You need to press F8 before the Windows screen appears...after you switch ON your laptop.
Posted on Dec 10, 2009
How do I get my computer of of safe mode
in safe mode, click the start button and then "run"
In the "run" window type: msconfig
and then hit enter or ok. You should now see a "system configuration" screen, at the top are several tabs and one should be labeled "Boot"
Near the bottom of the window should be several box's you can check or un-check, most likely your safe boot option is checked.
So un-check safe boot (don't think anything should have check marks in them) and then hit OK. Windows should then ask you if you want to restart.
Once restarted you should be in normal windows :)
Sep 30, 2014 | Microsoft XP Computers & Internet
Asus icore 5 s.m.a.r.t error
S.M.A.R.T is a HDD program, http://en.wikipedia.org/wiki/S.M.A.R.T.. Have you tried a system restore/recovery? If it's ten days old send it back for a replacement, do not wait. They should send you a replacement. Be Persistant. Do not take no for an answer.
Nov 05, 2012 | ASUS U52F-BBL9 Laptop
How do I start acer iconia in safe mode
Hold the power button in for the count of ten, it should shut it down and cause it to ask you to boot up in safe mood, it may take a couple of tries but it will eventually go to a menu to ask for the boot mode....I recommend spyhunter4...I just removed that virus from a clients pc two days ago
Oct 12, 2012 | Acer Iconia TAB W500-BZ467 10.1 inch AMD...
I bought lenovo b3 series 3 days ago n not it doesn't start normally , i hv to start the pc in safe mode n then i can use it, why?
Safe Mode is for trouble shooting only. I would take it back immediately if it's new.
You should have never had to use the disc, being so new. Unless it was a floor model?
Sep 25, 2012 | Lenovo IdeaCentre B305 Series Black...
Hi my acer lap top is in safe mode and wont start if i buy a fix it cd will this work thanks alicia
Since you can boot in safe mode, teh you should try using the SYSTEM RESTORE to take it back to the day the problem started, try that first.
For example of XP: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Mar 17, 2011 | Acer Computers & Internet
My laptop was a gift xmas 1 year ago. when i turn it on there is a black screen and then there is this message ; it say sorry for this problen windows didn't start normally. then it gives me 4 or 5 choices...
#2 "safe mode with networking" will only work if you were attached to a local network and configured to boot from it. This is not the normal configuration for most users. The network they are referring to is NOT the internet.
You should try #1 and after it is booted try a restart [Start], [Shut down], then use the pull-down to select Restart. If once it
Feb 25, 2011 | Computers & Internet
I got a pop up saying my computer was infected. I tried to restart my computer and it just comes to a black / blank screen. Can I save my files or will I have to reinstall windows.
Restart into safe mode either F8 or F12 depending on your computer just get to the safe mode feature, button when you restart keep pressing it until it loads. Once there go to run type in MSCONFIG click it then go to restore computer and go to a date earlier than a day or so ago and restore it. I hope this assisted you without the hassle of doing a full system restore. You can access through the back door which is SAFE MODE. Then you can go in and restore back to a earlier time. Or if you know where the problem came from get rid of the software as well you know that caused the problem. Be sure to dump cookies and history each day as well. John
Jan 22, 2011 | Computers & Internet
Windows does not shutdown properly, asks me if i want to restart in safe mode?
It never hurts to start in safe mode. While in safe mode, some things will not be available to you. Be aware that there is a reason your computer is telling you to start in safe mode. Something happened, hardware or software related, that caused a problem. Windows allows you to start in safe mode to correct problems. Not knowing what the problem was, I might suggest starting in safe mode, then go to start, all programs, accessories, system tools, then system restore. Try to restore your computer to a few days ago when it was working properly. Then restart, and hopefully it will work.
Aug 22, 2010 | Acer Aspire One PC Notebook
Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
May 09, 2009 | Computers & Internet
PLEASE HELP
HellaNice is correct, check for errors. Could be corrupt files.
May 16, 2008 | Dell Latitude D505 Notebook
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
