Question about Samsung UN65D8000 65" 1080p LED-LCD HDTV, Dolby Digital Plus / Dolby Pulse, USB, Built-In Wi-Fi, Black
I have a badly cracked 65" sumsung tv screen,can it be replaced?
Replacement
  • Samsung Master
  • 933 Answers
Yes sir it can, but the cost to replace will exceed the value of the set. Check a video we made last year that indicates just how thin and fragile LCD panel are. Will help you understand why they crack so easy!
http://www.youtube.com/watch?v=8uZnc98n6kk
Posted on Jan 20, 2013
    Top Expert:
  • Samsung Master
  • 3,107 Answers
Generally speaking, though it may be possible to fix a broken screen, it's not cost effective and you'd be better off replacing the TV.
Posted on Jan 25, 2015
2 Suggested Answers
moorah1
  • 181 Answers
SOURCE: I have a Samsung HP-T4264 plasma tv with a badly
No way, Jose!
Those bastards manufactures are always making sure you won't be able to use parts from one model to the other. Especially-display! LCD panels could be rigged, but no plazma's. Sorry!
Sell it for parts to some repair shop and get yourself LCD or LED panel. Plazma is gone!
Posted on Jan 21, 2010
What part do I need to replace when my DLP tv bulb cracked after I turned off the tv?
Hello, all i can say is it may have been a bad lamp, see if they'll warranty it....tks
Dec 23, 2014 | Mitsubishi Diamond WD-65831 65" Projection...
Samsung tv cracked screen
Hello Sam, it would cost more to replace the screen than you can purchase a new set for. Beside that the new set will have many updates if your set is over 3 years old. p.s. If you have little ones, you may want to have a piece of lexan cut to fit the front of your new set and attach it with 4 pieces of velcro in the corners to protect the new screen. Then if you want you can remove it for "movie night's" or whatever. the $50 to $65 it would cost is a lot cheaper than a new tv.....tks Terry
Apr 18, 2014 | Samsung Televison & Video
Broken screen on model WS-55311 MITSUBISHI
If its the outer protective screen that u need I have one. I didn't like the glare it provided me with so I took it off. Email me remarkable14u at yahoo dot com.
Dec 25, 2013 | Mitsubishi WS-65809 65" Rear Projection...
Screen
This is a huge cost to replace one a TV screen is broken it is cheaper to buy a new TV than replace the old one.
May 09, 2013 | Mitsubishi WD-65731 65" HDTV
Inside screen has small crack in it and only getting half of tv
For the cost of the panel, you could purchase a 65" LCD TV with a service contract and delivery. For some reason, Sharp replacement LCD panels have such a cost factor that repair is never economical. It's a sad ordeal, because they do make a reliable product (which I do recommend). I hope this was helpful, best wishes.
Apr 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
A small crack in my hitachi tv screen
very espensive. new. try to find used one.  change yourself.
Dec 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replacement Screen for 65 " Sony Color Rear Video Projector
Try HERE to get replacement screen for your TV.
Good Luck.
Sep 26, 2008 | JVC AV-48WP30 48" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
BROKEN SCREEN
I had the same problem I had to get a UX26083 from Ued.net. now i can't install it!
Dec 30, 2007 | Hitachi 65F59 65" HDTV
Samsung UN65D8000 65" 1080p LED-LCD HDTV, Dolby Digital Plus / Dolby Pulse, USB, Built-In Wi-Fi, Black Logo
416 people viewed this question
Henry  Thomas
Henry Thomas
