Question about Cameras
Nikon L110 won't accept SD 16 GB card. - Cameras
    Genius:
  • Cameras Master
  • 1,669 Answers
Attached is a list of approved memory cards for your camera:
http://support.nikonusa.com/app/answers/detail/a_id/16781/~/approved-sd-cards---coolpix-l110
Posted on Jan 19, 2013
Dshack
  • 40 Answers
SOURCE: just bought a 16 gb
Try formatting the card.
As I am not familiar with the Panasonic cameras, nor did you say what card type you were using, I cannot give specifics on what to format it to (if using a computer) or how to do it through the camera, which may have an error and not recognize the card due to a lack of proper formatting, and thus may not allow you to access the card at all, even to format, or if your camera is able to format the card at all.
Specifying what brand and model of card you are using would help.
Posted on Dec 16, 2008
SOURCE: will the kodak easyshare z730 accept the pny optima sd hc 4 gb me
No, because the camera is too old to be compatiable with teh SDHC its only compatiable with SD not SDHC.
Posted on Mar 02, 2009
  • 102366 Answers
SOURCE: Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
Posted on May 19, 2010
  • 102366 Answers
SOURCE: Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Posted on Jun 03, 2010
Obertelli
  • 3006 Answers
SOURCE: What is the largest size
The DMC-FZ7 is designed to work with SD cards up to a maximum 2GB capacity (4GB in theory, but very few devices work reliably with the 4GB SD as they simply didn't exist at the time so could not be compatibility tested with most SD devices). You have tried an 8GB SDHC card which the camera is incompatible with.
The SDHC card is the same size and shape as SD but is significantly different "under the hood". SDHC compliant devices can use earlier SD cards, but devices which are not designed to use SDHC cards cannot be updated: the incompatibility lies at the basic hardware level so there is no firmware update to overcome this.
So your guess is correct, but I hope that my reply helps you to understand why. Your fix is therefore to stick with SD cards of a maximum 2GB capacity. As SDHC cards start at a minimum 4GB capacity, you have no risk of buying the wrong model.
Please take a moment to rate my answer.
Posted on Sep 24, 2010
My Nikon L110 will save videos but not pictures. I've formatted the card and checked it on my computer. It's a new card also. I've tried changing the card but still the same issue. Please help!!
Did you format the SD card on the computer? If you did....format the card in the camera and make sure the lock on the SD card is off.
May 04, 2017 | Nikon Cameras
If my Nikon Coolpix L110 does not accept the memory card, whilst the card works in the computer, what is the problem with the camera, and how do I fix it?
Your camera is SDHC compliant, so the card should work in your camera. There are two things you must do. Check if the Lock "switch" is NOT in the lock position and second before using the card in your camera, you should format it in the camera. Although FAT32 is supposed FAT32 for every device, camera's can be very "picky" when it comes to formatting and saving pictures. Even when a card is formatted in a Coolpix L110 from someone els, it could be your camera can't work with it.
I hope al the contacts in the camera are still clean and shining and not one os bent or has (even the smallest) dent. Check this with a stri=ong light and eventually with a magnifying glass.
Jan 30, 2015 | Nikon Coolpix L110 Digital Camera
WHERE CAN I FIND A SD MEMORY CARD,NOTSDHC
Yes, SD memory cards can still be purchased.
May 21, 2014 | Nikon Coolpix L110 Digital Camera
Not read memory card
The Coolpix L110 can work with SD and SDHC cards up to 32 GB. If you bought a SDXC card, it won't work in your camera. I don't think Nikon will come with an update of the firmware, only for bigger memory cards, because you can shoot hundreds of pictures already on a 32 GB card. Also be sure the Lock switch on the side of the card is in the unlock position. Like the 64GB card on the picture.
Jan 08, 2014 | Nikon Coolpix L110 Digital Camera
PC cannot recognise usb for nikon l110
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
May 07, 2012 | Nikon Coolpix L110 Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
My camera,s model is nikon coolpix l110. But unfortunately showing message your memory card is write protected , that's why i can not take any picture.So please fix this problem.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2011 | Nikon Coolpix L110 Digital Camera
What kind of memory card will i use in this camera. Are all memory cards have a standard size.
You may use any SD or SDHC card. All SD and SDHC cards are the same size physically. Electronically, SD cards range up to 2GB while SDHC cards range from 4GB to 32GB. Any of them will work in the L110.
Dec 01, 2010 | Nikon Coolpix L110 Digital Camera
It says this card cannot be used. what is the biggest sd card i can use?
The S1 uses SD cards. SD cards top out at 2GB, any larger cards are actually SDHC (Secure Digital High Capacity). SDHC devices will accept SD cards, but SD devices will not accept SDHC cards. They will fit physically but not electronically.
In fact, the S1 manual does not list any cards larger than 1GB.
Jan 26, 2010 | Nikon Coolpix S1 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
