Question about Roper Washing Machines
Check filter error - Roper Washing Machines
    Sergeant:
  • 291 Answers
Have you checked the drain pump filter for debris? YouTube has videos on the procedure. Also repairclinic.com may have videos.
Posted on Jan 19, 2013
F21 error on Kenmore washer
The F21 drain indicates a long drain. There are several reasons for the error. The most common causes are debris in the drain pump filter or excessive suds. If you aren't using HE detergent or if you use too much detergent, the excess suds may be the cause. First, remove the clothes from the washer. Try running the washer without adding more detergent.
To check the filter, you will need to unplug the washer. Next take off the bottom panel. Locate the drain pump and the adjacent filter. Have a bucket handy to catch the water from the pump. Open the filter and remove any foreign objects. Look into the pump and check for any objects that got past the filter. Remove anything that doesn't belong. See the cabinet and pump diagrams here: http://www.searspartsdirect.com/model-number/11049972602/0583/0153200.html to help you take apart the unit and locate the pump filter. Close up the filter and try running the washer (again no clothes and no detergent). If the error does not recur, you've solved the problem.
If the F21 error repeats, then the pump or the water pressure switch could be faulty. If water has been pumped out of the washer, then check/replace the switch. You should also check the wiring between the switch and the main control board.
I hope this helps.
Jul 26, 2016 | Kenmore Washing Machines
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
My Maytag Duet washing machine is getting F21 error message because the machine is not draining properly
Check the filter at the base of the machine to ensure there are no blockages or debris in the filter.
Be prepared to catch the water that comes out.
Feb 07, 2011 | Maytag Washing Machines
My lg wm12225fd direct drive error 1E
Is it 'IE' ? There is no '1E' error code. Input error. Is water turned on? Are waterline filters clear, the ones between the hose and the unit?
Apr 07, 2017 | LG Washing Machines
F02 error Pump Filter hoses all ok. Whirlpool duet front load.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have checked the filter and pump in my washer but still get the sud and f02 error code. What else can I do?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&@$^@#
May 21, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Error message to clean the filter, but it's clean.
i would check underneath the washer to see if there is a sump filter fitted {older hotpoints used to} if there is clean this and that should sort if not fitted check all the pipes on the drain output to see if any blockage{causing a restriction} as this could be causing the computer to think the filter is blocked. i hope this is of some help
Jul 23, 2009 | Washing Machines
F02 error
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Please rate my solution.
Thanks.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
