Samsung WF218ANW/XAA error code OE - Washing Machines
5 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
kvhappliance
  • 218 Answers
SOURCE: WF218ANW/XAA not accepting cold water, only hot?
Hi you most likely have a bad water fill valve.
part # "dc62-30314k"
This is a common failure on all washing machines.
If I can be of further assistance please let me know.
Posted on Mar 18, 2010
  • 354 Answers
SOURCE: Samsung front loader model number
Well unplug and hope that powers down your solenoid that is keeping it closed. Whats happening is that it thinks there is still water in there and it doesnt want you opening it. So if there is no water in there turn off circuit breaker off then back on or unplug for a moment to see if it resets itself. It should open on power down and if nothing else clear itself on reboot (yes there is a computer in there) . I would say you have a faulty sensor or the sensor is staying wet some how . try those and let me know
Posted on Jun 23, 2011
machineindep
  • 55 Answers
SOURCE: I was Samsung washing machine model number WF218ANW/XAA It's making a flapping sound in the back during a spin cycle.
unplug and re-plug the Washer and check if the issue persists. otherwise click on this link for chat support http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=346139&modelname=WF218ANW&modelcode=WF218ANW%2FXAA&session_id=QBLGXKdDpFv5J32LF2rR81JCHqnryJpb6V1ldwQh6Wt1RQfLhRQy%211780044318%211589942691%211354844292695&from_osc=#
Posted on Dec 07, 2012
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
No power to washer, can't open the washer door
http://www.appliancepartspros.com/parts-for-samsung-wf218anw-xaa-0000.html Look at the video section to see how to get under that machine and open the door and drain it.
Oct 04, 2015 | Samsung WF218AN Front Load Washer
My Samsung front loader is taking in water and flashing 0E. Can you help tell me what my problem is? Thanks
An OE code (not 0E) is an overflow error. Too much washing powder/liquid may have been added. Turn off power, wait 30 seconds and turn on power again. You should hear the drain pump operate to drain the machine.
Feb 22, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Error code oE
According to page 25 of the users guide you can download from Samsung's web site at http://www.samsung.com/us/support/owners/product/DMR57LFS oE means, "Water level error (over-level)"
Jan 20, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
Dec 06, 2012 | Washing Machines
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Mar 18, 2010 | Samsung Washing Machines
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
