Question about Saws
Kinzo angle grinder switch
How to get to switch
  • iain264
    iain264 Jan 21, 2013
    I've taken out all the visible screws and it still won't come apart any ideas ?
2 Suggested Answers
Mike258
  • 1498 Answers
SOURCE: Fault on a Kinzo 115mm Angle Grinder
Hi J,
Hopefully you just wore out the brushes. Replacement kits are available for a few bucks and the fix is pretty easy.
On the darker side, If it overheated enough that it burned the windings (insulation melts, shorts, badness), there isn't much you can do unless it's still under warranty.
You won't know until you get it apart. You'll know which it is at a glance.
Unplug it and dismantle the base of the grip where the cord is attached.
The brushes are small spring loaded graphite blocks that transfer electricity to what looks like a cylinder around the central drive shaft that has a lot of vertical copper strips on it. They are normally housed inside small copper tubes opposite each other.
If those tubes are empty but for the spring, it's brushes.
If the insides are full of ashy residue, it's not the brushes
Best regards and I hope it it's the brushes
Mike
Posted on May 27, 2010
Testimonial: "Excellent-many thanks."
How to fix makita 5" grinder
It is time to replace the trigger switch.
May 08, 2014 | Makita 9005B 5" Electric Angle Grinder
Makita 18v angle grinder red light on
Check these sites: https://www.ifixit.com/Wiki/Makita_GA4030K_Troubleshooting or this one: http://www.doityourself.com/stry/troubleshooting-your-malfunctioning-angle-grinder
Jul 01, 2012 | Makita Angle Grinder BGA452
My makita angle grinder(9527NB) the on switch only works when it wants to. Turn it on dont work, bang it and it might work. Any suggestions
This is definitly a bad switch. You can contact Grainger or MSCDirect, and give them the model number and the make/ They should be able to send you out a new switch. These are pretty basic circuits and only take about 20min to replace.
Jun 08, 2011 | Makita Angle Grinder
How do you remove and release the quick grinder pad?
There is a button at the front of the grinder usually black or red, depress it lightly and rotate the wheel (unplug grinder please) wait until you feel it fall into spot, depress tightly and hold then turn wheel and unscrew to replace pad. Reverse to reassemble.Good Luck....
Apr 21, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
I have mac allister angle grinder the problem when switch on the geinder start and suddenly stop and showing over loaded
Hi ibychackoja, It is the problem of the carbon brass replace it with a new with the identical size of the old one. Feel free to ask whatever the results.
Regards; VOTIT
Dec 03, 2010 | Makita Angle Grinder
Hi J,
Mike
May 27, 2010 | Dewalt DEWD28110 Heavy Duty 4 12"...
Bosch angle grinder stopped cold when tapped lightly
Yes, if you have taken the handle halves apart (unplug tool first) check with your meter thru the blades on the cord to the switch contacts and then lock the switch in the on position and check across the switch and then remove the brush caps and brushes and check thru to the brush holders, if at any time you lose continuity then that would be your problem. Let me know if I can help further.
Mar 09, 2009 | Bosch 5" Small Angle Grinder
Saws Logo
104 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
