Question about Drills
Replacing brushes on makita hr2470t percusion drill
Having trouble replacing brushes
    Champion:
  • 304 Answers
Turn the brush ring anti clockwise so the top brush is to the right as you look at it. lift the spring out the way and hook it to the side of the brush holder. you can then remove and replace the top brush easily.
For the bottom brush remove the switch from the machine by undoing the cable clamp and pulling the two push on wires to the field just above the switch in the housing. Then turn the brush ring so that the lower brush holder is in the middle and remove the brush as you did with the top one. After turn the ring to one side and refit the switch. Job done. (Don't forget to release the springs back onto the brushes.)
Posted on Jan 29, 2013
  • 313 Answers
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Posted on Jun 09, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
  • 3 Answers
SOURCE: i HAVE TWO BROKEN MAKITA lxtbhp 351 z DRILLS. i
yes it is possible but you may find both gear boxs have gone in the same place it is a common problem with this drill gear box is £66
Posted on Jan 31, 2010
kirkx
  • 2019 Answers
SOURCE: makita bdf452hw drill the brake does not work.
Yes it is probably the trigger, that makes the current go in reverse to act as a brake.
Posted on Feb 26, 2011
rowdy45176
  • 2176 Answers
SOURCE: How do you remove brushes from a makita cordless
you will need to GENTLY pry up on the brush shunt that you see and remove them. reinstall in the reverse order. they generally have a somewhat tight fit in the brush/motor tube
Posted on May 07, 2011
Makita 6227dwe cordless drill can the brushes be replaced.
No, unfortunately this is brushes only come as part of the motor assembly Makita 6226DWE 3 8 Cordless Driver Drill Parts
Dec 24, 2016 | Makita Drills
Makita hr3851 won't hammer or drill
Try pulling out the brushes and blow some air in were the brushes go it may have gotten some trash in between the brush and the armature . they may need to be replaced, here is a pleace that will give you a breakdown and sell you the parts. http://www.ereplacementparts.com/makita-hr3851-rotary-hammer-parts-c-97_380_491.html
Jul 30, 2016 | Makita Drills
Hi,I have a makita impact driver, I press the trigger and don't work, only the light come on,I replace the trigger but I still have the same problem.
I would guess that you have a motor issue. It maybe as simple as needing new brushes. I have an Makita impact at work and it has carbon brushes and if one of those goes bad or hangs up it will stop the driver. Hope this helps!
May 14, 2015 | Makita Drills
Makita troubleshooting
The BDF452HW has a carbon brush motor - and they do eat up brushes quickly. The brush set number is CB440 - they are replaceable by removing the 2 screws on the rear cap, the connectors snap over the brush holder - take care not to bend the brush holders when changing, they are just thin brass.
If the tool is 'ticking' or 'grinding' when it spins check the condition of the armature before you install new brushes - the copper commutator should not look burnt or have raised segments - this is also a common repair on this tool. Replacing the armature is a fairly inexpensive and easy fix - you must split the entire clamshell housing to access this - be sure to fit all the components securely back into their slots or you may tear all the fan blades off the armature when you try and run it.
Jul 27, 2014 | Makita BDF452HW 18V Cordless Lxt Lithium...
Why will my Makita drill not work when the battery is charged?
Could be the the brushes need replaced , how old is the drill
new brushes cost £4.26 inc vat and are simple to fit.
Jul 06, 2014 | Makita 12 Volt Cordless Drill/Driver Kit
Replace brushes on makita bhp452 drill
Here's a link on how to remove brushes.http://www.youtube.com/watch?v=x-drC2HEzRo
Oct 06, 2012 | Makita Bhp452Rfe 18v Cordless LXT Combi...
Need carbon brushes for makita mod#m601 10mm drill
I could only find a 601D which is a cordless drill with a sealed motor so you can't just replace the brushes and the motor is discontinued.
Mar 31, 2012 | Drills
How do you remove brushes from a makita cordless drill, the brushes are situates each side at the back cover by caps when i remove cap what do i do next?
May 07, 2011 | Makita Drills
How to dismantle a makita HP electrical hammer drill, want to replace the brushes
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Sep 13, 2010 | Makita HP1620F Electric Hammer Drills
My makita hmo860c breaker drill has stopped working power light is on ?
I purchase a rotory hammer on ebay and it was listed as a makita, i was trying to get a spare part for it from makita. I gave them the information that is printed on a lable on the side of the drill, 66015c, 850W 110V,26mm and to my suprise they told me that it was not one of their drills, I have a few of these drills still being sold on ebay as makita. is there anyway that anyone can help me with this query.
Aug 30, 2009 | Makita Hammering
Drills Logo
287 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
