Question about Compaq (253219-002) Motherboard
Lcd screen black sometimes
I have a princeton graphics vl180 monitor and after i let it sleep for a while sometimes it stays black. if i disconnect that monitor and put on the old crt monitor works fine. also if i let lcd monitor sit 6-10hrs it will turn on
  • 56 Answers
Try to change the LCD power settings ... this is a hardware assue ... but i think it will change when u change this settings
Posted on Jul 31, 2007
SOURCE:
The monitor stays black
unplug monitor cable with power on, see if any message will come up on screen, if message appears , cable replacement needed
Feb 19, 2014 | Princeton Digital VL1716 17" LCD Monitor
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
I reset the resolution on the computer (big mistake) and now I cant see the screen in order to reset it back. The screen turns all blue with two messages and a flash of the windows screen (windows 7). The...
Boot up in safe mode and selct VGA support, then set the video resolution to your Princeton VL2018 native resolution mode (1680x1050 @60 Hz)
See more here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Hopefully you monitor doese not have the same problem (bad caps) just like the other VL2018 as shown in my pictures here (but it will fail for sure later on):
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Jun 12, 2010 | Princeton Digital VL2018W Monitor
My princeton VL2018W will flash the screen when first powered on but goes blank after. With repeated unpluging, the display used to stay, but no luck
floresa57, After lcd panel "flashes" is the lcd panel "black" or is it both "black" and "blank" when you perform the flashlight test that every LCD owner should know how to do and interpret the results? Do you have warranty? If no, then read more responses in my FIXYA profile for clues on what YOU will or what YOU won't do to fix your BLACK SCREEN monitor!!! Floresa57, the basic principles of design and operation of your Princeton VL2018W are same as all other brands of Fluorescent backlit LCD monitors!!! It can be fixed. READ, READ, before you do anything. Understand the reason WHY your monitor is now black and lifeless. Follow all the LINKS to other web sites so you will be informed and less likely to be overcharged on a repair job that should have cost less than $50. Good luck Floresa57. Rate this on FIXYA if it was of some use to you. 12fixlouie
Jan 05, 2010 | Princeton Digital VL2018W Monitor
I can not go past 1152 by 864 resolution, the screen will turn off and flicker also now it looks like video shown on the monitor is very high in contrast and sometimes the monitor will be on but no picture...
This means that you have reached the limitation of the graphics card of the PC that you have connected to it. You could try changing the Refresh rate of the card to see if you can get a higher resolution.
Oct 14, 2009 | Princeton Digital VL180 18.1 in. Flat...
When turned on the green on light works and the screen appears and then goes on and off wont steady stay on
Check the Ram in your PC. Refix the Ram. If the problem not solved replace ram by a new one
Jun 27, 2009 | Princeton Digital VL180 18.1 in. Flat...
Monitor goes blank
Sometimes, i can be the wiring, so check all of that. But apart from that. I don't know! Hope this helps!
DigicalJAI
May 21, 2009 | Princeton Digital VL1717 LCD Monitor
PRINCETON LCD-15BLK MONITOR
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Missing ribbon wires
There is no chance of getting parts for that model of lcd. It is obsolete.
Mar 17, 2017 | Princeton Digital VL180 18.1 in. Flat...
Compaq (253219-002) Motherboard Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
